im in need of the last 50cm of a 40/45 series cruiser driveshaft.
i need it to mate the rear uj to my front yoke on my project.
itll eliminate the need for an adaptor to be made...
so if anyone has one with a buggered front half would be ideal if you could cut the rear part off for me..
wtd, cruiser rear d-shaft uj
Re: wtd, cruiser rear d-shaft uj
might have one kicking round here somewhere.. i'll have a look as I know I have a fk'd front ds from a bj70.. so should be the same.. let me know if that'll do the job..
as long as the flange is the same itll work.
will it have a short section of tube with it? no problem if it doesnt...
my driveshaft that its for is only about 500mm long
here's a pic
Tube is close to 65mm at the flange end on the rear of the shaft.. flange fits my 80 series rear axle so should be good for ya $50 for the whole thing and i'll be coming down either this weekend or next.. let me know
yeah sounds good if it fits mine..
Cool i'll let ya know when Im heading down if you're not in a hurry..
