Got a complete LJ71 Prado rear diff/axle assembly for sale. Complete with nasty clunk so a new ring & pinion will be required. This is (was) the heavy duty 'V6' 8" 4.88 ratio.
Vented rotor disc brakes over handbrake drums. Standard 6 stud Toyota hubs. 1415mm wide between hub faces. Radius arms to suit included plus a spare pair also - some new bushes needed in these. $150 the lot.
Pair 40mm lift EFS rear coil springs to suit LJ71, good condition: $120
I need a 35-36" spare wheel on a 16" rim with 12-25mm backspace, or a straight LJ71 passenger door, so will consider a swap if you happen to have either of those lying around.
Pick up only on the diff, can freight the springs at buyers expense. Located 20km out of Rotorua at lake Rotoiti.
Clint
ph 027 212 4485
Toyota LJ71 rear axle (buggered R&P) etc
UZJ71 Landcruiser
KTM 640
KTM 640
- mudlva
Re: Toyota LJ71 rear axle (buggered R&P) etc
i have a 35x12.5x16" radial tyre only if you can find a rim for it
approx 5-6mm tread and i think it is a yokohama geolander tread pattern
$125.00
$125.00
Price reduction: $150 for the axle etc, $120 for the springs. Last chance, they will go on trademe next week.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
