80 series rotors
firestonecruiser
80 series rotors
Post by firestonecruiser »
after some 80 series rotors if anyone has some spare. mine are getting a bit thin and slightly warped causing a slight vibration,
cheers jono
Big
Re: 80 series rotors
Post by Big »
BEst get new ones and pads.. goto BNT they are very reasonable think mine cost like 50 bucks each + 1 set of pads for $10.. and they work great..
pressy
Post by pressy »
firestonecruiser wrote:after some 80 series rotors if anyone has some spare. mine are getting a bit thin and slightly warped causing a slight vibration,
cheers jono
Hi jono,
I had something like a shudder under braking, and have finally found the cause to be the brake calipers in the front some of the pots had seized, re kitted and now all ok.
Return to “Toyota”
