Anyone have a link for the wire diagram for the dash on a Prado 90 1kzte (auto)
My speedo is cutting in and out causing the engine check light to come on (is this bad?) I've checked it a the transfer case and all is well.
Prado 90 1kzte wire diagrams
Re: Prado 90 1kzte wire diagrams
there might be one on www.pradopoint.com
Did you get this sorted? Having the same problem
nah havent been able to track it down.
- Newbie
Hey there myn does this to sometimes im new to the 1kz got a lj78 and done conversion was a misson changed dash and everything got some stupid questions its a 1kzte bloody big transfer case does anyone no how many leters of oil and what to use in her as gona do my self bloody get ripped off in christchurch 9 times outa 10 they ovee fill in under cheers
Transfer Case takes a little over 2 liters.1kztejameschch wrote:Hey there myn does this to sometimes im new to the 1kz got a lj78 and done conversion was a misson changed dash and everything got some stupid questions its a 1kzte bloody big transfer case does anyone no how many leters of oil and what to use in her as gona do my self bloody get ripped off in christchurch 9 times outa 10 they ovee fill in under cheers
Basically on level ground, fill it to it overflows out of the fill hole.....Which is on the back of the case... about 1/3 of the way up. Looks just like the drain plug.
If you run a pto, it will take a but more.
