is it good offroad and whats it worth
nizute
Post by nizute »
Hey guys i haven't had much to do with these, how good offroad are they and any idea how much to offer on it? body is rusty,chassis is good and v8 with manual gearbox
Ralfie
Re: is it good offroad and whats it worth
Post by Ralfie »
Bloody good off road.
Late 70's model from the looks.
They have same chassis as the later Discovery up to 1998.
Same basic design still exists in latest Defender.
Hard to say what its worth, depending on running gear if body rusted.
It will all be inner rust as well because outer panels are alloy. Is it still registered or rego on hold?
These older models are becoming sort after as collectors items now due to age. anything from $200 to $1200 perhaps.
It would be neat to have one again, but with later fuel injected motor.
nizute
Post by nizute »
No its dereg but i have way to fix that thanks to a mate!! :wink:
ice4x4
Post by ice4x4 »
Does it run?
You won't get a more capable open diffed 4x4 out the box.
I wouldn't be paying any more than $600 for it if it is dereged and doesnt run.
1988 Range Rover Classic
2010 Discovery 4 HSE 5.0 V8
[img]http://i251.photobucket.com/albums/gg303/eastw77/2_zpse514cc6c.gif[/img]
noexitroad
Post by noexitroad »
if you don't want it then pm me, i might be interested
nizute
Post by nizute »
ice4x4 wrote:Does it run?
it used to but i havent seen it move in nearly 2 years so it will need some tlc before it does again.
ant-neil
Post by ant-neil »
5 6 Hundy dereg . I have brought a few discos for around the grand mark wof regd
nizute
Post by nizute »
Cheers Guys i will go see if i can haggle his price down :lol:
RRS
Post by RRS »
2 door rangies were fantastic.
But why don't you the same thing a cheaper way by buying a diesel D1 that's ready to go.
Do you want to be a fixit man or go off roading?
nizute
Post by nizute »
Tru but i enjoy building my projects and i got my ute for now but wouldn't mind building my own thrasher.
nizute
Post by nizute »
Well it took awhile but i managed to talk him down from $1500 to $600 so after i get rid of all the terrano parts i will drag the old girl home for a good going over!!!
Any tips to get the best out of her without going to overboard on mods??
noexitroad
good effort.
maybe start with tyres before going over the top with other stuff?
nizute
Post by nizute »
noexitroad wrote:good effort.
Yea rims and tyres are a bit f***ed anyway , does anyone do aftermarket steel rims ?
Mehrts
Post by Mehrts »
Toyhatsu Bitsalux
zukmeista
Post by zukmeista »
No rover 5-stud there? They are 5x165 i think? The ones in that link are 5x150 which are landcruiser.
nizute
Post by nizute »
Yea i have rung our suppliers they can't do so rang BG worldwheels but they wanted $260 a rim for steel so may either import some or get the engineer who made our stock car rims to make me some.
DieselBoy
Post by DieselBoy »
nizute wrote:Yea i have rung our suppliers they can't do so rang BG worldwheels but they wanted $260 a rim for steel so may either import some or get the engineer who made our stock car rims to make me some.
Give www.landroverspares.co.nz a call, he can get new rims of what ever size and width you desire for good prices and may even have something 2nd hand kicking around if your realy lucky.
Www.landroverspares.co.nz would also be my first point of call for any parts you need to get the old girl up and running. The best service from a parts supplier you'll get in the country.
lokrite
Post by lokrite »
You can run a 15x7 or 15x8 mangels rim with kings hd rear springs but dont forget to flatten the forward seam in the guard as it cuts tires real well on max compression . The 15 rims are easy to get and about $140 the 16s are the expensive ones . Your rims look like they have been widened out what do they measure , standard was only 61/2 according to my book . Disco rims are 16x7 but the positive offset gives you a terrible turning circle and you need the correct nuts .
nizute
Post by nizute »
Give http://www.landroverspares.co.nz a call, he can get new rims of what ever size and width you desire for good prices and may even have something 2nd hand kicking around if your realy lucky.
http://Www.landroverspares.co.nz would also be my first point of call for any parts you need to get the old girl up and running. The best service from a parts supplier you'll get in the country.
Cheers for that!!! its good to know who to get hold of when i need parts
nizute
Post by nizute »
lokrite wrote:You can run a 15x7 or 15x8 mangels rim with kings hd rear springs but dont forget to flatten the forward seam in the guard as it cuts tires real well on max compression . The 15 rims are easy to get and about $140 the 16s are the expensive ones . Your rims look like they have been widened out what do they measure , standard was only 61/2 according to my book . Disco rims are 16x7 but the positive offset gives you a terrible turning circle and you need the correct nuts .
Not sure what the rims are i haven't got it home yet, the king spring is that a lift or standard height heavy duty spring?
Should i get a set of lift springs and what height should i get?
lokrite
Post by lokrite »
The springs I ran on my 88 4dr were heavy duty for lpg tank in back .They gave about 30mm lift and a nice firm ride on the road I tried 265x 75 x16 bfg ats on the alloy rims but they rubbed on rear inner guard to much so sold them and went back to 31x10.5 x15s just have to watch that guard seem you will see it ,big hammer to flatten . If you have access to a lathe you can make up 30 mm alloy packers to fit under springs which work well with out to much expense , check out the kings spring web site it has a good catalogue with lifts
cheers nick
nizute
Post by nizute »
Cheers for the advice nick!!!
nizute
Post by nizute »
Just a update , i wont be going ahead with the rover due too having to grow up and buy a house so all the toys are going!! If anyone is interested in the old girl PM me and i will pass on the detail so they can get it for the same price.
slidenyo
Post by slidenyo »
yeah nah you have to keep it now? you already saved $900 on the price,
and 4x4's are useful especially if you're buying a house,
for example: gardening lawn and tree and shrub removal,
painting and maintenance as a mobile scaffold,
landscaping to tow feature rocks logs and a levelling bar around the lawn.
I even used my last burnout car to relocate my garden shed and move 6m prefabbed garage walls around to the garages present location.
never sell your toys especially the bargains,
I could go on about the old mans brock commodore that he sold when I was 8 but that's just dumb.
don't tap out because the toys you have before you buy a house are easy to keep and the ones you try to acquire afterwards are hard to get.
kind regards Jase
1972 b1600 supercharged 3.8 v6 tipper project
1983 Gemini wagon turbo 5.3 v8 project
05 Suzuki rmz450
70 s2a ld28t landy on cruiser diffs project
burnout/dirtdrags diesel project
05 avalanche mrs car
I had all my projects mapped out and bought when I purchased property now all they need is time as the money has been spent
nizute
Post by nizute »
Yea i have been holding on to them for this long but when i touched the rx7 since i did the rollcage and homoligation and that was 4 years ago and the gsr hasn't been touched since i rebuilt the motor a year ago they are lot of coin just sitting there. Don't worry tho i am keeping one set of toys!!!!
