I hope you understand me
If not sorry
hello
nissan terrano2 2.4i
I have a stuttering problem idling
I am driving the car everything is fine and works nicely round
Cnl even after prolonged standing
After a short drive the car heats up it starts to stutter idling
If I run air conditioner does not stutter no nothing
Replaced ignition wires plugs fuel pump fuel filter
And performed all testing to the proper ignition
Engine does not draws air or blower and a good Hkmfrsih
Last week I went after a period of no sand
"Ripped" the car sands
And what happened was added to a new problem
Car stuttered very strong and the clouds of black smoke out the exhaust
Gasoline engine!
No Diesel!
terrano II Problem of stuttering
- Crash bandicoot
Re: terrano II Problem of stuttering
from what i can make sense of it sounds like the air flow meter is in need of a good clean atleast... and a new air filter as if what you are saying is right then dust and light particles are getting past the air filter
Ok
I'll see what you wrote down
Air filter is new
I'll check the sensor
Air filter is new
What motor is it? Z24, KA24E or DE?
- Crash bandicoot
they came with a ka24e, (intercooled) td27td and eti and the zd30
hamboy wrote:What motor is it? Z24, KA24E or DE?
mine it's ka24
Ah sweet if its not the AFM check the valve that controls the choke as it can stick and cause random weird idling and sometimes black smoke (overfueling)
