Is someone with a D21 Terrano service manual able to tell me the coolant capacity?
The R20 Mistral one states 10l with overflow tank, but I couldn't get anywhere near this even with a proper drain and flush
Leon
TD27T Coolant Capacity
Re: TD27T Coolant Capacity
details from the only terrano manual I have,
too bad it doesn't have the TD27, but ya learn to deal with it
- Crash bandicoot
from the workshop manual for the facelift R20.
Engine oil (Refill)
With oil filter TD27Ti 6.2 5-1/2 API CE, ACEA B2-96 (CCMC PD1), D5 level
SHPD (*1)Without oil filter TD27Ti 5.5 4-7/8
With oil filter ZD30DDTi 6.7 5-7/8 API CF4 or ACEA B3-96. 98 or ACEA B3/E3-
98*4Without oil filter ZD30DDTi 6.2 5-1/2
Cooling system
Total capacity
(With reservoir tank)
TD27Ti 10.0 8-3/4 Anti-freeze coolant
(Ethylene glycol base)
ZD30DDTi 10.6 9-3/8 Genuine Nissan Anti-freeze Coolant (L2N) or
equivalent*5
Manual transaxle gear oil
FS5W71C 3.5 6-1/8 pt API GL-4 (*1)
FS5R30A 3.6 6-3/8 pt API GL-4 (*1)
Transfer TX10A 2.3 2 API GL-4 (*1)
Differential oil
R180A 1.3 2-1/4 STANDARD:
R200A 1.3 2-1/4 STANDARD:
API GL-5 (*1)
H233B
(LSD) 2.8 4-7/8 Use only LSD gear oil API GL-5 and SAE 80W
(*2) approved for NISSAN LSD
Power steering fluid 1.0 7/8 DEXRONTM
Brake and clutch fluid — — DOT 4 (USFMVSS No. 116)
Multi-purpose grease — — NLGI No. 2 (Lithium soap base)
Air conditioner system
refrigerant R134A
KLH00-PAGROlubrication oil
Don't forget the block will never actually be totally empty as the lowest drain isn't at the lowest point of the water jacket...
Engine oil (Refill)
Cooling system
Total capacity
equivalent*5
Differential oil
API GL-5 (*1)
H233B
refrigerant R134A
