TD27T Coolant Capacity
For all Nissan related topics
Bonus
Post by Bonus »
Is someone with a D21 Terrano service manual able to tell me the coolant capacity?
The R20 Mistral one states 10l with overflow tank, but I couldn't get anywhere near this even with a proper drain and flush
Leon
JayWetere
Re: TD27T Coolant Capacity
Post by JayWetere »
details from the only terrano manual I have, :roll: too bad it doesn't have the TD27, but ya learn to deal with it
Crash bandicoot
Post by Crash bandicoot »
from the workshop manual for the facelift R20.
Engine oil (Refill)
With oil filter TD27Ti 6.2 5-1/2 API CE, ACEA B2-96 (CCMC PD1), D5 level
SHPD (*1)Without oil filter TD27Ti 5.5 4-7/8
With oil filter ZD30DDTi 6.7 5-7/8 API CF4 or ACEA B3-96. 98 or ACEA B3/E3-
98*4Without oil filter ZD30DDTi 6.2 5-1/2
Cooling system
Total capacity
(With reservoir tank)
TD27Ti 10.0 8-3/4 Anti-freeze coolant
(Ethylene glycol base)
ZD30DDTi 10.6 9-3/8 Genuine Nissan Anti-freeze Coolant (L2N) or
equivalent*5
Manual transaxle gear oil
FS5W71C 3.5 6-1/8 pt API GL-4 (*1)
FS5R30A 3.6 6-3/8 pt API GL-4 (*1)
Transfer TX10A 2.3 2 API GL-4 (*1)
Differential oil
R180A 1.3 2-1/4 STANDARD:
R200A 1.3 2-1/4 STANDARD:
API GL-5 (*1)
H233B
(LSD) 2.8 4-7/8 Use only LSD gear oil API GL-5 and SAE 80W
(*2) approved for NISSAN LSD
Power steering fluid 1.0 7/8 DEXRONTM
Brake and clutch fluid — — DOT 4 (USFMVSS No. 116)
Multi-purpose grease — — NLGI No. 2 (Lithium soap base)
Air conditioner system
refrigerant R134A
KLH00-PAGROlubrication oil
Don't forget the block will never actually be totally empty as the lowest drain isn't at the lowest point of the water jacket...
Return to “Nissan”
