LJ71 prado parts F/S
slide
Post by slide »
I have a LJ71 prado parting out.
PM me offers for parts, or ask here.
Engine, transmission and front axle gone.
(still have 2.4 EFI fuel pump&ecu)
Has factory e-locker rear diff lock (4.88:1) (works but motor sad).
Am willing to store parts until suitable freight (ORE courier etc) sorted.
Nathan
imsohi
Re: LJ71 prado parts F/S
Post by imsohi »
hey dude
have you still fot that centre consol around the auto shifter?? also wing mirrors & the heater shut off valve in the engine bay, the stuff i looked at ages ago :roll:
I made another trans from a few parts ones i had on the cheap. :D
Should be over for the 4wd club anniversary 8-9 nov
Cheers Leigh
slide
Post by slide »
Hey Leigh
Yep, got heater shut off valve. Which part of consol were you after? ( I forget now :roll: )
Maybe I'll Pm you a photo tomorrow and get you to circle bits you wanting?
Mirrors I've still got at this stage
Nath
imsohi
Post by imsohi »
the main part around the shifter and it houses the ect and power buttons
slide
Post by slide »
Yep thats no problem. I'll get bits out so you can get weekend 9-10th when you're over
Clint
Post by Clint »
Hi Mate, have you got a passenger door? Doesn't have to be perfect, just moderately straight & non-rusty. If so I'll check out the freight cost.
Clint
UZJ71 Landcruiser
KTM 640
oldblue
Post by oldblue »
Looking for a Electric Window Switch off the Drivers side door ( # 84820-87010 ) would it be the same as a 1993 Prado ?.
slide
Post by slide »
I'll check numbers on it for you
Edit- found number 74231-60050 on the plastic trim part, only number I see on switch part is 289-5p21
Where did you get the "84820-87010" from?
Maybe I got a missing sticker?
slide
Post by slide »
Clint wrote:Hi Mate, have you got a passenger door? Doesn't have to be perfect, just moderately straight & non-rusty. If so I'll check out the freight cost.
Clint
Passenger door is dead straight and no rust.
Yea, check freight cost and make an offer
oldblue
Post by oldblue »
From Toyodiy.com.
Looks like its the same part. you can email me oldblue@clear.net.nz
slide
Post by slide »
Trademe auction for cab- going cheap :D ;
http://www.trademe.co.nz/Browse/Listing ... =660829792
redz driver
Post by redz driver »
looking for front brake calipers thanks
Real men drive swb leaf spring trucks
slide
Post by slide »
redz driver wrote:looking for front brake calipers thanks
Can't help ya this time sorry
kzn130smurf
Post by kzn130smurf »
Hey, is the rear diff a 8 inch?
u13turbo
Post by u13turbo »
Was it auto? If so could you tell me the trans code off the tags
allmud
Post by allmud »
hay mate just looked at the trademe pics do u still have the rims ?
slide
Post by slide »
Yep, was auto. Trans code a343f
And yep 8" diff G144.
And yep, have still got rims from trademe pic
imsohi
Post by imsohi »
Hey do you have that Ect i will be over next weekend and how muchy. Cheers Leigh
slide
Post by slide »
Yep, got that waiting for ya. PM sent
