At this point I thought rather than throwing money at a panel beater, a cheap welder, some scrap panel steel and some rattle cans should have her all patched up and that magic sticker on my windscreen. Little did I know, the mess hiding beneath the bog would put paying someone way out of my reach anyway.
Here it is before the grinder came out. You can just see the 50cent piece size paint bubble under the vent next to the door hinge. That is what prompted this project... my finger went right through it.
This is the aforementioned area after a bit of wire wheel action. Sweet mother of body filler, what have I gotten myself into. Strangely, the area covered by the diamond plate is mostly sound.
Some champion has just bogged straight over gaping rust wounds at some point in the past. And as I would slowly find out, this awesome handiwork was repeated right around the rest of the tub.
This is the same area, but driver's side
The bog was 6-8mm thick in some places.. the old 3M dust masks were worth their weight in gold.
Bottom of the drivers side B pillar after a bit of cutting, where the main hoop of the cage mounts to the floor. This was nothing short of shagged. None of this was visible beneath the filler.
The underside of the main spar behind that previous photo
All this led to some extra ventilation being installed courtesy of the cut off wheel.
The grinder had developed a mind of it's own by this time, and
'a couple of patches, nothing major' turned into bare metal for most of the tub.
Tread plate, off with ye!
Yep, that's FUBAR.
'Surprise.. the other sides just the same.
