the over drive light has just started to flash,
the speedo is working fine and it drives normally
it wont go into over drive at all,(normally it was approx 85-90kms,
any thoughts appricated
over drive light flashing. 1993 surf KZN130, auto
Re: over drive light flashing. 1993 surf KZN130, auto
this is because a fault has been detected by the ECU and thus set your truck into limp home mode.
the number of flashes before a pause is the diagnosis code.
- mike
- Last minute Mike
Same truck and year as mine and mine has been doing it since 2008, speed sensor on the auto or something someone once told me. My auto just locks up ten k's later (90-95) and thats the only side effect I've had. Kinda annoying towing but thats about it.
If you do fix it, would be keen to one day fix mine.
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
1994 Toyota Surf
Hope these help you guys out.
Cheers jordan
P.s if you have more then 1 code i recommend writing them down
clearing the fault codes and drive till they return.
Cheers jordan
The_wehi@hotmail.com
(027 788 1046)
Pzj77 Turbo/auto,33's .
(027 788 1046)
