Installed the hi pinion E-locker
Mattman wrote:Really just the control arm mounting points on the chassis. Did you use the Prado arms?
Matt.
Mattman wrote:Nice one - were the mounts a reasonable price?
How did you work out where to weld the mounts - trial fit and check for travel etc?
Apparently there are two types of Prado linked diffs, an early and a late. The late is the one to go for as it artics better apparently. Do you know which you have?
Matt.
hosehustler wrote:well I just had a hell busy weekend, lkids, xmas parties, truck mods, and tried to get to Riksooking forward to going back to work tomorrow for a rest and thats not good coming from a fireman :fire:
got the beast back on the wheels now offically to tall to climb into for someone my height, did some measurements new front shocks required have to be 720mm long. minimum!steering box in place mounts to finish, marlin crwler all finished driveshafts measured ready for lengthining/shortening, still desperately need a mid bowl sump for a supra tho, anyone
I think the sump is gonna be the hold up, sorry no pics, no cam
will try to get some of the finished result
rokhound wrote:My new (slightly worn, but new toi me) tyres arrived for the wreck on Friday.
Gonna be interesting getting them on.
But they are farking big at 39.5 x 16.5 x 15.5.
billyvanboheman wrote:Low and behold, today the clutch slave cylinder crapped it's self on top of Westfield Riccarton![]()
Tried to bleed it but I think it's poked![]()
About to venture out there and pull the damthing to bits![]()
