Trundles Automotive are now New Zealands Sole agent for Amada Extreme suspension !!
We have a 20ft container landing early next year with lifts for every thing from Basic hilux 2" shocks , to 5" patrol resivior shocks , To coil over lift kits for new hiluxs , kzj185 etc ,
We have over 400 shocks on the water , Remote bump stops etc
And are currently looking for a South island Agent also ,
As used by superior engineering and winning competitions thoughout the world !!
Below is a peek at the highly affordable resiviour shocks !!!
New Zealand Agent For AMADA EXTREME 4wd Suspension!!!
Moderator: Vendors
- Attachments
- amada extreme.jpg (7.62 KiB) Viewed 21893 times
Re: New Zealand Agent For AMADA EXTREME 4wd Suspension!!!
Good move...look forward to seeing your pricing.
It's a hassle bringing my shocks in from Aust when I need them!
I cant confirm now untill i pay duty and tax but in Australia they retail them at 1300 australian plus tax and i was planing on doing the resiviour ones For around $1200 inc gst nzd and the Adventure series for around $600 inc a set but maybe Cheeper if possible ,
Hi Mate, after a set of rear shocks for my Prado thing (80 series cruiser rear diff & coils) 19mm eye top & bottom Compressed length between eye centres 425mm, then as much extension as ya got, ideally to more than 700mm. I think this is around the same spec as a 4" lift GQ Nissan.
Space is a bit tight so would prefer something with a rubber boot rather than a steel shroud.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
Do you have any listings for a R50 Terrano?
Need to track down some 50mm lift rear springs or 50mm poly spacers, and rear shocks suitable for the 50mm lift.
Hey i am looking at getting some 14" coilovers to replace the ones in my truck as i want some remote reservoir shocks. I was wondering if you could tell me the thickness of the mounts for them so i know how far to weld the axle mounts.
Sam
Sam
Hi mate are you meaning for the eyelits on the ends or extended and compressed lengths ,
I have another 4 sets twin sprung exo resiviors coming on this order
Hey sorry yeah the eyelets
Sam
Sam
BUSH – Length 49.8MM, Inner Diameter is 12.5MM and the Outer Diameter is 22MM.
