cracked my 1kz head what to do now?
surfee
Post by surfee »
any one have ideas as to wat to do. do I fix it or throw it away and repower it with something like a 5L v8?
uptomynutsinruts
Re: cracked my 1kz head what to do now?
Post by uptomynutsinruts »
Fix it go genuine head if you can
dutchy
Post by dutchy »
re power with 1jzte :twisted:
Surf - 50mm lift, front bar, integrated winch etc
contactable on 0220901730
prado_boon
Post by prado_boon »
Fix it with genuine Toyota head. It'll last you another 300+k's
mike
Last minute Mike
Post by mike »
second that. Fix it with genuine, get at least 2.5" exhaust from dump pipe out, get an egt gauge, bypass egr, external trans cooler, remove internal trans cooler, 4 core radiator with larger fin spacing to reduce clogging(optional), intercool if you can be bothered and you should have an awesome engine. Love my 1kz!
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
oldblue
Post by oldblue »
Ive done 100,000km plus on a Toyota replacement head. All good. :D
firestonecruiser
Post by firestonecruiser »
fix it or buy my 80 series cruiser.
cheers jono
mike wrote:second that. Fix it with genuine, get at least 2.5" exhaust from dump pipe out, get an egt gauge, bypass egr, external trans cooler, remove internal trans cooler, 4 core radiator with larger fin spacing to reduce clogging(optional), intercool if you can be bothered and you should have an awesome engine. Love my 1kz!
don't forget to check/fix/replace viscous fan hub
nathan @ kaipoi repowers does dump pipes
TerrainTamerNZ
Post by TerrainTamerNZ »
+1 to Genuine, however we have sold many after market heads too and had no issues to date, but if you are towing or wheeling I would recommend Genuine. We have a bare genuine head with head set and head bolts in stock if you are interested. PM or give us a call for info.
Daniel
Daniel Stebbings
0800 287 278 | 09 263 6021
facebook.com/terraintamer | youtube.com/terraintamer4wd | twitter.com/terraintamer4wd
timmay556
Post by timmay556 »
Jerry wrote:
mike wrote:nathan @ kaipoi repowers does dump pipes
Do they sell just the dump pipe?
ie it bolts up to standard exhaust?
dutchy
Post by dutchy »
+1
got 2.5" to dump pipe, would like to go 3" dump
stealth
Post by stealth »
not a direct bolt in replacement unfortunatly
