I have a 1993 VZN130 as my daily runner and just got a wrecked 1989 VN with 255000 kms and 3.8 V6 with auto in it.
I have 3 main questions Im hoping youse lot can answer for me,
1) Is the VN motor going to be any more economical than my current toymotor v6? (opinions seem divided)
2) I hear and read about diff ratios. Im guessing if I change the rear diff I will have to change the front diff also to keep things turning evenly in 4WD? If thats no problem will the standard commy diff in the donor car bolt into the surf without too much effort?
3) The transfer case adaptor kit from this mark chap is a bit steep for current budget, is there anyone in NZ that can provide a cheaper option? I tried calling a ton of wreckers but having no joy getting a used set up. It looks like the output shaft has to be removed and im guessing cut down then a modified housing fitted to the back of the box? Thats all i can tell from the searches Ive done so far anyway.
I might have not used all the right key words in my searches so some of this info may be out there already, would appreciate a heads up if you know where to find it.
Also Im in Wellington and can swap live crayfish for parts
