Warn 9.5ti motor
Warn 9.5ti motor
Hi All
I haven't been on the forum for a while but I need some help if possible.
I buggered the motor on my warn 9.5ti, I would like to upgrade it (HP) if possible and wonder if anyone has a done this and was it successful and if so what motor did you use, any help much appreciated
Also looking at dyneema rope probably 10mm, any brand that stands out better than others or who does a good deal?
Paul
Paul
Trust me, I know what I am doing
Cheers Pradozer
Cheers Pradozer
Re: Warn 9.5ti motor
See warren at 4wdbits.. they have what would you need
4.8hp motor
http://www.4wdbits.co.nz/ProductDetails ... ductID=747
7.8hp motor
http://www.4wdbits.co.nz/ProductDetails ... ductID=749
otherwise trademe and search..
4.8hp motor
7.8hp motor
Big wrote:See warren at 4wdbits.. they have what would you need
4.8hp motor
7.8hp motor
Yes seen those but the 9.5ti has a pinion for the planetary gears, those motors have a spline so not sure if that will work
Paul
Cheers Pradozer
Cheers Pradozer
I guess warren will let you know when he see's this..
According to a Warn parts site your motor is a
http://www.gowarn.com/prodDetail.aspx?partNo=WAR64635 or
http://www.amazonsupply.com/warn-64635- ... B000OV6K9K
So they don't look anything special...But it may have a long splined shaft...
Hope this helps.
Hope this helps.
Batfastard
- Dr. Love Glove
I have a warn winch on the rear of reggie it has a super winch motor fitted to it it just bolted up sweet as
kbushnz wrote:According to a Warn parts site your motor is a
Hope this helps.
Hi Calvin
it appears that there are two types of motors, one for all the standard warn winches and another for the 9.5ti for the first set of planetary gears, I need to do more home work
Paul
Cheers Pradozer
Cheers Pradozer
Batfastard wrote:I have a warn winch on the rear of reggie it has a super winch motor fitted to it it just bolted up sweet as
Ok what model is your winch and what is the model of the motor
Paul
Cheers Pradozer
Cheers Pradozer
Geez dude, you make shitloads, just go and buy a gigglepin setup and bang it on. Should be able to claim it as a forklift or some sort of lifting device
Sorry mate, not much help to you, but I couldn't resist being a smart arse
rokhound wrote:Geez dude, you make shitloads, just go and buy a gigglepin setup and bang it on. Should be able to claim it as a forklift or some sort of lifting device![]()
Sorry mate, not much help to you, but I couldn't resist being a smart arse![]()
Ah a forklift, that would have been handy last week, would have needed 35" tyres though.
I am beyond help anyway and I know you couldnt resist being a smart arse, I would think you a not feeling well if you were polite
Cheers Pradozer
Cheers Pradozer
- Bulletproof
Why do you need a new motor Paul ? You got a problem
On the other side of the Reefton saddle after going up Trev's hill and down Cooze's track. A lot of winching as the ruts are very deep and even 36 simex's will not touch the bottom.
On a serious note. Warn claim these winches are water and shit proof.What a load of bullshit as I have had the same trouble as Paul and they just self destruct with condensation buildup.
Cheers Richard
Cheers Richard
Never say die, up man and try
Watching the pennies is probably why he has lots of money
Who knew Prados could fly?
Hi All again
Ok having done some homework it appears that the 9.5ti is the only winch that uses its type of motor with the 12 spline so I am looking at upgrading the motor to 20 spline and an adaptor to the 12 spline current set up.
This is where I need help, I need someone in Christchurch area with a dead warn winch in pieces I could get measurements off to see if I can do an adaptor.
I f anyone knows of one could you let me know please, my phone numbers are 03 327 5103 or 021 472 853, any help appreciated
Paul
Paul
Cheers Pradozer
Cheers Pradozer
- evolution02
If your interested and it's what your after I have a brand new winch motor for sale. I brought it when I was rebuilding a burnt out warn winch but found it was to long to fit inside my winch bumper
It is identical to this
- Attachments
- image.jpg (28.59 KiB) Viewed 11645 times
evolution02 wrote:If your interested and it's what your after I have a brand new winch motor for sale. I brought it when I was rebuilding a burnt out warn winch but found it was to long to fit inside my winch bumper
Yes I am interested, is it 12 volt? and do you know what Hp rating etc and what length is it, is there any part numbers on it I could look up?, txt me you number and I will call you 021 472 853, cheers Paul
Cheers Pradozer
Cheers Pradozer
