A mate ripped a hole in his housing and bent it out of shape, so is in need of a replacement housing, with or without axles.
Hilux rear diff housing required. CHCH if possible
Re: Hilux rear diff housing required. CHCH if possible
Smurf wrote:A mate ripped a hole in his housing and bent it out of shape, so is in need of a replacement housing, with or without axles.
a wide axle surf one? leaf spring or coil I have both.
trucked wrote:Smurf wrote:A mate ripped a hole in his housing and bent it out of shape, so is in need of a replacement housing, with or without axles.
Leaf sprung, narrow hilux one.
I got a narrow one here in chch 021 5 444 57 . can have with or with out axles, cheers chopper
Chopper01 wrote:I got a narrow one here in chch 021 5 444 57 . can have with or with out axles, cheers chopper
Its for James, I'll tell him to get in touch with you.
- ClassicCruiserSpares
- Sausage Shack
Ive got a good bare housing here also
ive only got surf wide housings so no good
trucked wrote:ive only got surf wide housings so no good
Cheers anyway mate
