Can anyone confirm the length of a Vitara CV shaft (output flange side, ie long side of the diff) from output flange to seal face, as well as the total length? This is for a 1996 1.6 SWB, not the V6. I have some confusion about whether there are two different lengths available between V6 and 1600.
Help would be appreciated. Thanks.
Vitara CV Shaft Lengths
- Chairmen
Re: Vitara CV Shaft Lengths
From what i've heard the V6 is a wee bit longer then the 1600 in length, I assume its obviously to compensate for the wider track width..
I have a V6 passenger's side axle sitting in the garage if you do want the measurement's it wont be much of a hassle ?,
How-ever hopefully someone can put up the length of the 1600 axle shaft as i have always been curious as too the difference in length's..
Hi Ross
I get 385mm from flange to seal face and about 510mm over all.
Cheers Woody.
Cheers Woody.
Hey Woody
Thanks. That 25mm shorter than the one we have? It's labelled as being for a 5dr V6.
We might be about to make a mistake. Might see if I can get the ones in our zuk measured to be certain.
It sucks having everything in different cities.
The 1600 early escudos/vitara are the shortest front axles
the early V6 shape are the longest front axles (approx 20mm longer), and the 98-05 shape Grand vitaras are smack bang in the middle between the two.
