spotlights with h4 bulb.
vvilly
Post by vvilly »
Hey all,
just scored some spotlights with h4 bulbs.
They have three wires coming out the rear of them.
Question?
Does anyone have a wiring diagram.
Im thinking 1 wire high beam 1 wire low beam 1 wire earth.
vvilly
Re: spotlights with h4 bulb.
Post by vvilly »
vvilly
Post by vvilly »
also run a switch after the fuse from the battery ???
slide
Post by slide »
diagram looks good if its a common earth system. some put power to bulb, then earth either high or low to make it work. I forget which system the toyota uses (easy to check with a testlight).
are you using offroad? if onroad it'd pay to double check wof requirements for amount of dip lights you are permitted. may have to make them so only come on when high beam activated, but have a switch to choose between hi-and-lo on spotlights
vvilly
Post by vvilly »
slide wrote:diagram looks good if its a common earth system. some put power to bulb, then earth either high or low to make it work. I forget which system the toyota uses (easy to check with a testlight).
I have got spotlights currently on the truck. They are on seperate switch and not wired through high beam they can be turned on with park, dip and high. Never been pinged.
think its factory wiring too
ChurchurDan
Post by ChurchurDan »
You are only allowed 2 lights on low beam. I would hook up the high beam part of them as a normal driving light and not do anything with the low beam. Put your switch in line with one of the wires switching the relay.
vvilly
Post by vvilly »
Can I run the dip and high at same time will that make any different
slide
Post by slide »
It may make too much heat inside the spotlight for the bulb having both going, leading to early bulb failure
vvilly
Post by vvilly »
Thanks mate
