ln106 diff swap
mayder
Stropper
ln106 diff swap
Post by mayder »
hi i got a ln106 its got 4.3 ratio diffs lsd rear open front does anyone know if you can pur the lsd in the front and the open in the back so i can put locker in
churchill
Re: ln106 diff swap
Post by churchill »
Check the ramps on LSD, if they're symmetrical it'll work in reverse as well as it does going forward so swap away. If they're not you'll get difference performance in each direction, up to you if you mind this.
tuff lux
Re: ln106 diff swap
Post by tuff lux »
yup u can mate i did that exact same. went straight in and no problems what so ever
Smurf
Re: ln106 diff swap
Post by Smurf »
Diffs are interchangeable, just be aware you should trim 3-5mm off the inner ends of the front axles to get everything to fit
dian1111
Stropper
Re: ln106 diff swap
Post by dian1111 »
This is very good :)
____________
daily deals, online shopping sites, hot deals, best deals
Return to “Toyota”
