looking for some c33 rear springs for the rear of my truck.
will look at other lift bits if anyone has em springs shocks chamber bolts shock extenstions spacers.
vitara lift stuff c33 laurel springs wanted.
- You Get That
Addicted to suzukis....
Re: vitara lift stuff c33 laurel springs wanted.
If you were closer I could help you.
They'll be easy to find, c33 laurel, a31 cefiro and s13 silvia all have the same rear springs btw. S13 may have a lighter spring rate.
also s14 silvia rears may fit too.
PS, are you saying the rear springs in my parts vitara will lower my cefiro?
- You Get That
got it lifted a31s in the rear and vls in the front... the vls had to be heated an srunk at the top and now its given it a big lift!
so now its all up to wack big camber, big cv angle, springs hitting breaks causeing break fade and even with a strut flip my shocks won't reach through the struts!
so now looking for..
front diff drop brackets
extended front shocks/extensions (asapj)
mabey aftermarket front arms
I had the same brake issues. Returned it to stock and truck sold before i fixed it but i figured I'd have to limit the lock a tiny bit to combat it. I didn't just have brake fade though so be careful, at full lock I had no brakes at all. Springs were quite bowed from memory too. I had planned to alter the bottom arms to seat the spring better, was going to cut the spring seats and lower the inner side a bit to level them. If i did it again on a roady I'd probably stop being a cheapskate and just get proper lifted front springs or arms.
- You Get That
yeah ill see how much i have to limit the steering before it hits or i may just go to standered v6 springs because they should be skinnyer
