KL71 or MT764 or MT117
Mattman
Post by Mattman »
Looking at a new set of 33s.
The Maxxis Bighorn and Kuhmo Kl71 both get good reviews.
Anything else I should be looking at in the sub 400 per tire range?
Edit: post updated to include the Silverstone.
Matt
Suza
Re: KL71 or MT764?
Post by Suza »
Savero MT are worth looking at
Mattman
Re: KL71 or MT764?
Post by Mattman »
Cheers - who stocks them?
Weeds
Re: KL71 or MT764?
Post by Weeds »
I brought some from Firestone railway ave couple of month ago petone
mud_slinger
Re: KL71 or MT764?
Post by mud_slinger »
i would go for the bighorn 762 personally.
savero should be available thru any tyre shop
needs more curry
0272593533
Mattman
Re: KL71 or MT764?
Post by Mattman »
Roughly what are the saravos worth?
I thought the 764 was a replacement for a 762 and more aggressive?
Matt.
Weeds
Re: KL71 or MT764?
Post by Weeds »
Carnt remember exactly but think thay where round the 300 mark for 33s good bang for buck
Mattman
Re: KL71 or MT764?
Post by Mattman »
That's quite a bit cheaper than the Bighorn or KLs.
What sort of Terrain do you run?
Mattman
Re: KL71 or MT764?
Post by Mattman »
Just had a look online. They look identical to the Buckshots which I currently have.
Suza
Re: KL71 or MT764?
Post by Suza »
Not quite more like the old BFG's.
I have run them for 4 years now first on a Bighorn and now on a Safari and have found them to be the best all round tyre I have used. I do every thing from highway (I do drive this a lot due to where I live), but I also drive west coast, farms, snow, high country and rivers
4WDbits
Re: KL71 or MT764?
Post by 4WDbits »
6 of one and half dozen of the other. Both have similar performance on and off road although tread patterns are totally different.
If going Maxxis, go with the MT764 if available in the size you want, bit more aggressive tread and more durable.
muddy
Re: KL71 or MT764?
Post by muddy »
KL71 wear VERY fast
Drurban
Re: KL71 or MT764?
Post by Drurban »
KL71's are a good road tyre not so good for the mud I have had mine going on 4 years now and I have done quite a few K's on them so they are getting bald now.
As above post they dont wear quickly.
Chur
KIWI_TERRANO
Re: KL71 or MT764?
Post by KIWI_TERRANO »
Drurban wrote:KL71's are a good road tyre not so good for the mud I have had mine going on 4 years now and I have done quite a few K's on them so they are getting bald now.
Chur
Newer kl71 do, had mine 40tho and there toasted mate, had some on my surf 3 year ago same at the same km still had 10mm of tread
luckyme
Re: KL71 or MT764?
Post by luckyme »
Chur
I'll second that, used KL71s on my surf for years and now on the Jeep, they wear f*ck all with right pressure on trucks around the 2ton mark.
Apparently they wear worse on the heavier trucks. Paid just over 300 per tyre not long ago, thats including fitting and balancing.
My 2c
Mattman
Re: KL71 or MT764?
Post by Mattman »
luckyme wrote:
Chur
My 2c
What size was that for?
tallsam66
Re: KL71 or MT764?
Post by tallsam66 »
KL71 are under sized .... so a 33 will be more like 32 , the are real quiet & drive well on the road.... but they do wear fast if you don't have them at the correct pressure on the road.
luckyme
Re: KL71 or MT764?
Post by luckyme »
Mattman wrote:
luckyme wrote:
Chur
My 2c
33x12.5x15
luckyme
Re: KL71 or MT764?
Post by luckyme »
tallsam66 wrote:KL71 are under sized .... so a 33 will be more like 32 , the are real quiet & drive well on the road.... but they do wear fast if you don't have them at the correct pressure on the road.
never came through size issues with them, might have to measure them up 8)
WRNGLR
Re: KL71 or MT764?
Post by WRNGLR »
Mattman wrote:Looking at a new set of 33s.
Matt
Check out Federal Courgias Matt , A mate of mine got 5 33s from Feilding tyres for about $1450, awesome in the mud, very cool tread pattern
Tarmac
Re: KL71 or MT764?
Post by Tarmac »
As far as 71's being undersized..... almost all of them are - what rock are you under??? Sorry to sound harsh but most if not all apart from high dollar ones are less than the advertised dia...
luckyme
Re: KL71 or MT764?
Post by luckyme »
Tarmac wrote:As far as 71's being undersized..... almost all of them are
So that makes no difference for the topic then ;) I thought it was an issues like it was with the silverstones before they changed the mould.
DEATH_INC
Re: KL71 or MT764?
Post by DEATH_INC »
Just a wee note on the kl71 thing, We've been advised by the Kumho guys that you MUST run 45psi on the road to get decent mileage. No more, no less. :mrgreen:
klompy
Re: KL71 or MT764?
Post by klompy »
I cant fault my KL71's and will buy them again.Never bought them as a mud tyre or expected to be good in mud,but they are great on road very quiet and handle well.
Mattman
Re: KL71 or MT764?
Post by Mattman »
Wow 45 psi seems high. What are peeps running?
Heath
Re: KL71 or MT764?
Post by Heath »
I ran between 40-43psi in mine.
Crash bandicoot
Re: KL71 or MT764?
Post by Crash bandicoot »
40 on road and well what ever floats my boat off road so to speak usually around just under half that.
WRNGLR
Re: KL71 or MT764?
Post by WRNGLR »
I usually run 36 on road and make them look like jandals for off road depending on severity of terrain
hachi_roku
Re: KL71 or MT764?
Post by hachi_roku »
why dont you run Trepadores? much better tyre, i can get them for you for just a tad over $400?
poss682
Re: KL71 or MT764?
Post by poss682 »
WOW that's really high! your ride must be terrible.
I run 30 on the front and 28 on the rear in my Terrano
Return to “Tyres”
