1kz or 3vZ?
co_ree
Stropper
1kz or 3vZ?
Post by co_ree »
Hey guys
Im looking to buy a surf but am stuck whether to get the 3kz diesel 3L n/a or the 3l v6 engine. I sometimes budget for cash with petrol vehicle licensing and gas and was just wondering is getting a diesel really that much cheaper as in will I cope with the added license cost and ruc? And I know diesels cheaper but does it make a big difference in fuelling up and how economical are these 2 engines? Any feedback will be greatly appreciated!
Mattman
Re: 1kz or 3vZ?
Post by Mattman »
The 3L v6 is very thirsty and not a good motor.
Go the diesel.
Matt.
catalystracing
Re: 1kz or 3vZ?
Post by catalystracing »
IMO do NOT buy the V6, had for awhile and tho we enjoyed the power and ride it was way too thirsty to run. 320kms to a tank on road and about 120kms in $WD. Thought the fuel gauge was a vacuum gauge it was a real :shock: :shock: :shock: at the pump. Now running a D/C Hilux with the 3L, love it to bits. Yup a little under powered by happy with economy and reliability. Easy to maintain and consumables from http://www.staparts.co.nz/ make it easy on the pocket.
If you check on TardMe dont be surprised if most are the petrol for sale, there is a reason
Go the diesel.
Matt. X2
co_ree
Stropper
Re: 1kz or 3vZ?
Post by co_ree »
Cheers guys thanks for the input, how many ks would you get out of a tank in the 3L diesel? And how much does it generally cost to fill up?
imsohi
Re: 1kz or 3vZ?
Post by imsohi »
in a 1kz surf (3 litre turbo) approx 85-90 to fill from dead empty and i would get 600 kms per tank now thats not you getting 600 per tank as i dont know how you drive but it is possible to do around the 10l/100kms.
Dont mess with the v6 Go the deisel
X3
Crash bandicoot
Re: 1kz or 3vZ?
Post by Crash bandicoot »
Believe us when we say a 1uz or LS1 are more economical then the 3vz.
Re: 1kz or 3vZ?
on a 1kz check the head viscous fan radiator, if its auto has the trans been regularly serviced, has the engine had regular oil changes, check for leaks
co_ree
Stropper
Re: 1kz or 3vZ?
Post by co_ree »
Oh ok sweet, what do u guys think about the 2.4 turbo diesel? 1991
sig
Jeep Jeep
Re: 1kz or 3vZ?
Post by sig »
co_ree wrote:Oh ok sweet, what do u guys think about the 2.4 turbo diesel? 1991
not much at all
Crash bandicoot
Re: 1kz or 3vZ?
not much at all
That particular power plant lasted all of......3 weeks before it got ripped out and replaced with a nissan one. 8)
Mattman
Re: 1kz or 3vZ?
Post by Mattman »
I have had a 2.4t and they are very under powered. They get thrashed hard and do heads/gaskets.
Heath
Re: 1kz or 3vZ?
Post by Heath »
There's no substitute for cubes.... except a turbo (but its just a crutch and not on a 2.4 diesel with toyota on the rocker cover).
3Lt maybe (older model but potentially not as temperamental as 1kz).
BlakeNZ
Re: 1kz or 3vZ?
Post by BlakeNZ »
Don't touch the 3 litre v6 petrol, or the 2.4 litre turbo diesel. The 2.4 non turbo doesn't do heads, but isn't very powerful.
Re: 1kz or 3vZ?
have had 2 of the
2l-te 2.4 efi turbo alloy head , cheap to run ( a days wheeling on a 1/4 of a tank) but the downside to this is gutless when you add weight bigger tyres . My old blue playdoh would get tyre spin on 33's bouncing off the rev limiter at just under 5k :lol: 2.4's suffer from the same head cracking issues as the 1Kz. they work but don't expect a power house ... if you get one replace it with a 3L 5L or 1Kz when it dies
Return to “Toyota”
