my old nissan 2.7 d was stuck in second removed computer
the computer in the side and the rear I take to control the outo trans now it runs with all gears how does this do this
I cant see how whats the computer for we must ask
was the computer box at buggered
hows does the trans run with out the computer
update now trans stuck in second with or with out computer is the trans stuffed or is is the speed sencer ontop of the trans
- Crash bandicoot
Re: my old nissan 2.7 d was stuck in second removed compute
philip121 wrote:the computer in the side and the rear I take to control the outo trans now it runs with all gears how does this do this
rear axcel fixed
I will bite. The TCU is there to simply tell the transmission the best time to change gear according to pre programmed parameters from factory.
Or you unplugged the wrong box....
How in the hell did you decipher that
well its got me
I was told the trans control was in the area where I removed but good point
lilpigzuk wrote:How in the hell did you decipher that
come on tell me the bad or good on this
- Crash bandicoot
ChurchurDan wrote:lilpigzuk wrote:How in the hell did you decipher that
Don't ask
and as for ya update there phil' it is now in limp mode you will have second and reverse till you plug the box back in. then you'll most probably have to reset the errors as the TCU will be awaiting on signals it ain't getting.
- Crash bandicoot
The easiest way to do that is put every thing back how you found it, then disconnect the battery and with the key in the on position stand on the brake pedal for a minute or so or leave an interior light for an hour, this will drain any residual power from the computer/s and it will use it's presets when the power comes back on....
This goes for any nissan too
I found another computer
still stays in limp mode the truck used to do this from time to time I would stop put into park and start again then it was ok now its in limp mode what ever I do how can I tell if its the trans itself
the computer that controls it or the speed sensor ontop of the trans
only other thing I did before this happened was put in new diff
ok the facts are it would now and then stick in second I would put in park and restart then it would be ok
I changed the diff last week truck was running ok then stuck in second I removed rr compter box that I take to control the trans
then the truck for an hour changed gears ok
I removed rlr compter box
still stuck in second
I replaced all computer boards
and disconnected battery
then re connect still stuck in second
it it the trans the sensor on top of gearbox or the trans computer
entertaining us usual
kiwinoz wrote:entertaining us usual
x2
I notice some of you once again good at running people down but very poor at trying to help with an anwer to my trucks problems
what is this place
we must ask a joke
what is this place
we must ask a joke
ask we must, planet from which are you?
- ClassicCruiserSpares
- Sausage Shack
You should get rid of the heap of shit!! It seems to constantly have major issues
Fukc being the poor bastard that buys it off this lunatic though.
Are you sure its the trans causing it to go into limp mode?
Limp mode is there for a number of reasons.
Have you checked the oil levels in everything?
The trans is fine,owners in limp mode.
klompy wrote:The trans is fine,owners in limp mode.
I think you maybe right
He's definitely not firing on all cylinders thats for sure
Perhaps the moderators of the forums could put a spam filter that you have to pass to prove you are a human and not a computer generated spam attack. If Philip121 had to pass this before he could post on the forums then that might solve the problem
ha
philip121 wrote:see I have shown the fakes up on this forum
run me down yes help or advice on trans no
that shows you lot up to what some of you are
ha ha ha![]()
Did you bother to actually look at what I posted ??
I think if you werent such a dick all the time people might actually give you some decent advice.
Page 16 tells you how to run the on board self diagnostics on the trans:
http://bebrs.pie-dabas.net/Webs/Terrano/R20/at.pdf
The sport indicator lamp they are referring to is the little orange light on the power/hold switch
DieselBoy wrote:The sport indicator lamp they are referring to is the little orange light on the power/hold switch
'Sport' and TD27 in the same sentence? Really? Haha
Jay wrote:DieselBoy wrote:The sport indicator lamp they are referring to is the little orange light on the power/hold switch
Why do you knock the TD27? It is just as capable as any other truck.
Ph 0212078472
Ph 0212078472
