Parts wanted!
For all Suzuki related topics
escudoboy99
Parts wanted!
Post by escudoboy99 »
Hey all. Im after some bits and peices for my zuki. For a start im wanting:
A pair of 1600 vitara front hubs (Complete assembly).
Some LWB V6 vitara springs or similar. Or any lift springs people have to offer. Let me know on prices for them and we can sort out something.
I have also got a collection of zuki parts that im wanting to sell off, so if anyone needs anything let me know and it check if I have anything.
Cheers Mitchell
tow99
Re: Parts wanted!
Post by tow99 »
Where are you? I've got some commy springs people use for the cheap lift
escudoboy99
Re: Parts wanted!
hey mate im in auckland on the north shore. do they use the commy springs in the front or rear set up. i currently have fts 3 inch lift springs in my swb v6. but they are too saggy with the front weight. need to get the front abit higher so im looking at other spring choices.
Swamped
Re: Parts wanted!
Post by Swamped »
it a roadie? I have some rear vl commodore springs that would fit the front. They aren't as nice a fit as aftermarket springs though so I'd keep em for offroad only.
ea falcons give another inch over the commys. The vl's gave ~2in lift and were real stiff.
escudoboy99
Re: Parts wanted!
Its heading towards being more offroad use then being a roadie as well. thats a good idea about the falcon springs over commie. do u know what type of falcon springs would be suited? could leave the 3 inch fts rears in and just play around with different springs. i also have 1.25 inch spring spacers up front which give 2.5inchs of lift when installed. might work with commy springs
oneinkedgeek
Re: Parts wanted!
Post by oneinkedgeek »
escudoboy99 wrote:hey mate im in auckland on the north shore. do they use the commy springs in the front or rear set up. i currently have fts 3 inch lift springs in my swb v6. but they are too saggy with the front weight. need to get the front abit higher so im looking at other spring choices.
Yeh if i was you id spend the cash on some springs from autolign, the ones i put in the 1600 gave me close to 3" lift, and then even after i swapped them into the 2litre truck with alot more weight in the front...was still the same or very close amount of lift. Rides mint on and offroad
escudoboy99
Re: Parts wanted!
I think that they would sagg to much Oneinkedgeek so im looking for something strong and stiffer.
"Swamped", I was wondering if these would be suitable or not?
http://www.trademe.co.nz/motors/car-par ... 529836.htm
Also where about's are you "swamped" i would be keen on trying the vl springs in the front!! thanks
1kz_surf
Re: Parts wanted!
Post by 1kz_surf »
im after a 1600 8 valve head if u have one? also a front left hub
lol
imsohi
Re: Parts wanted!
Post by imsohi »
escudoboy99
Re: Parts wanted!
hey 1kz-surf i dont have those parts sorry. 'imsohi' im after both fro.t hubs complete and a rear diff head if the wagon is manaul cheers
imsohi
Re: Parts wanted!
Post by imsohi »
was an auto but will have both front hubs will have to check condition of DS one as it was in an accident, what are they worth??
escudoboy99
Re: Parts wanted!
sweet. about $90 per hub complete is what il pay for them.
imsohi
Re: Parts wanted!
Post by imsohi »
Ok I will get out and get some photos this week for you
Rotazuk
Re: Parts wanted!
Post by Rotazuk »
escudoboy99 wrote: and a rear diff head if the wagon is manaul cheers
Looking at that I would say the diffs are the 5.12's same as a manual . Its not always the case but the only different ones I have personally seen come from a carbed auto . All the 16v auto are 5.12s . Only question may be some 8v SPI autos could have has 4.62's but I have not seen one . Only pulled about 7 or 8 apart so a wrecker would know more .
Guess what I am saying is its worth a count .
Chris
escudoboy99
Re: Parts wanted!
Yes that's right. The common ratios or the 1600 vitara's are 5.125 manual and 4.875 auto. Mine is a v6 manual vitz and it came standard with the auto ratio's so i have converted to 5.125 which gives me those extra revs. im keen on the hubs imsohi cheers
Pico42
Re: Parts wanted!
Post by Pico42 »
I may have some of the falcon springs, will have a look in the next few days.
I also have a few other bits and pieces to get rid of: I found a pair of Monroe struts (std height) today and have a m5000 winch (with m6000 for parts). Also looks to be a front diff in parts (alloy housing, 4.? Gears), prop shaft, drum brakes, steering shaft with bits4vits spacers, a 2+" body lift kit, maybe a CV or two (26 spline) and miscellaneous other suspension crap.
Anything of interest?
escudoboy99
Re: Parts wanted!
hey Pico42 i may be interested in the falcon springs.. I have got some commie springs of "swamped" to try out in the front of mine! How come your not using the steering spacer and bodylift in your little beast?
1kz_surf
Re: Parts wanted!
Post by 1kz_surf »
ive got a diff who ever was after one?????
manual 1600 swb ratio 5. what ever they are lol
Pico42
Re: Parts wanted!
Post by Pico42 »
escudoboy99 wrote:hey Pico42 i may be interested in the falcon springs.. I have got some commie springs of "swamped" to try out in the front of mine! How come your not using the steering spacer and bodylift in your little beast?
We added power steering - there is a longer steering shaft and the spacers were no longer required.
And we replaced the modified 2" body lift with a bits4vits 3" one.
Didn't see the falcon springs today while scratching around - but one box still to check.
EDIT - nope, falcon springs gone. Must have put them out in the last cleanout.
imsohi
Re: Parts wanted!
Post by imsohi »
escudoboy99 wrote:hey 1kz-surf i dont have those parts sorry. 'imsohi' im after both fro.t hubs complete and a rear diff head if the wagon is manaul cheers
Hey is this what your after?? been sitting for a bit but wheel bearings were good
And are you still after a Rear diff??
You Get That
Re: Parts wanted!
Post by You Get That »
I got some commy springs witch pretty sure gave me 3in lift in the front (they are still in the truck can measure) that I want to swap for some 2inch ones
Addicted to suzukis....
Return to “Suzuki”
