Project - Series 3 body on a 96 discovery chasis and running gear, powered by a mitsubishi canter 5 speed diesel. Turbo and intercooler to be added
EDIT Project engine is now a 3.5 rover v8, will look at supercharging it later
This is the current state of the old girl:
and this is what I am aiming for but with the same camo paint to keep the rugged look.
Current stage:
I stripped the roof, doors and back tray off. I found that tank no 1 has had a cracked filler and leaked diesel everywhere. The pump in between the tanks has siezed and needs to be fixed. I will keep the twin tanks for the long range ability, although this means fitting two tank mounts to the disco chasis it is well worth it in the long run. Without jerry cans the two 50l tanks can get it from chch to mount ruapehu without stopping for fuel.
You can see all the diesel soaked dirt everywhere. It was really caked on and hard to get at the bolts!
Next is the firewall, and the front panels to go. then comes the engine and gearbox. Stay tuned.
Mike
