l200 on 33s
- tirantious
- Bush Crasher
l200 on 33s
i was just sitting at home looking at my truck outside on 29s that just fit underneath it and wondered if anyone has ever lifted one onto 33s and how hard/ how much $$$s it would cost to do it. probabaly wont do it myself as i have no money with student loans
but i just wondered how well it would go and how well it would keep up with other lifted trucks haha
l200 with not a straight panel on it
Re: l200 on 33s
My L200 is on 31's with offset rims and I only had a problem with the rear of the front guards which got sorted with a grinder and a hammer
- tirantious
- Bush Crasher
Re: l200 on 33s
true hahaha i want to lift my truck eventually and turbo it or put a bigger diesel motor in first but i was just curious as to how well one would go with 33s under it ive seen tritons with 33s under them but never any older l200s with the 2.5s in them.
Re: l200 on 33s
in general terms you can expect it will make the gearing too high, overload the engine, burn the clutch out, chew up the tyres with guard rub, make the vehicle unwarrantable, over stress and break the CV's and bend/break the steering components all with a maximum on road speed of 75-80kph going down hill with a tail wind but the truck will look pretty cool
- tirantious
- Bush Crasher
Re: l200 on 33s
Re: l200 on 33s
i had one as a bush truck with a hory 2inch body lift on 33's never broke anything and it got a hiding. wasnt too bad on power even non turbo as it basically lived in low box
Re: l200 on 33s
there is a black one in palmy with 2inch body lift some trimming on the front guards with 33s
its a turbo one seems to go real well on and off road
looks cool to
looks cool to
- tirantious
- Bush Crasher
Re: l200 on 33s
hmmm sounds interesting hahah ill save up some money and go have a yarn with the local 4wd modifier guy and see what he reckons. ive already spent far to much on this truck to ever sell it so i might as well keep upgrading it
Re: l200 on 33s
i have 31s with wound up bars in the front have no problems with full lock will be doing body lift and sits at 100kph sweet as
- tirantious
- Bush Crasher
Re: l200 on 33s
cornflake wrote:i have 31s with wound up bars in the front have no problems with full lock will be doing body lift and sits at 100kph sweet as
my torsion's are wound up and the front sits quite allot lower than the rear but its only been like it since the truck got introduced to a concrete strainer and a ditch.
Re: l200 on 33s
tirantious wrote:cornflake wrote:i have 31s with wound up bars in the front have no problems with full lock will be doing body lift and sits at 100kph sweet as
take them out turn them on or 2 splines that is what i did almost sits even now
Re: l200 on 33s
My mates old L200 on 33's
He's seen the light and has a TD5 Disco now
Re: l200 on 33s
DieselBoy wrote:He's seen the light and has a TD5 Disco now![]()
The flashing ABS malfunction light??
Jokes, jokes
- tirantious
- Bush Crasher
Re: l200 on 33s
DieselBoy wrote:My mates old L200 on 33's![]()
hahah that looks mint. im always seeing lifted hiluxs and navaras around but never anything interesting like this. i think im definatly gonna have to save up and re-power the truck and get it on 33s just to be different.
wildplumdx
Re: l200 on 33s
i had 265 75 16s on mine and it rubbed but i cut back the guards and hit some stuff and it still wasnt the best so i went back to 31's still got the 265 75 16 which i think are 33s? sapped alot of power and drank more fuel was more the reason i went back to 31's
currently putting a bigger turbo on mine from 9b to 11g let you know how that turns out
- tirantious
- Bush Crasher
Re: l200 on 33s
wildplumdx wrote:i had 265 75 16s on mine and it rubbed but i cut back the guards and hit some stuff and it still wasnt the best so i went back to 31's still got the 265 75 16 which i think are 33s? sapped alot of power and drank more fuel was more the reason i went back to 31's
sweet as im thinking i might have enough money saved up and enough bills payed that i can swap the engine out from 2.5 non turbo to something with more guts by about christmas
- tirantious
- Bush Crasher
Re: l200 on 33s
well im giving up on 33s just to much money and to many other things to pay for.
however i have worked out why i couldn't wind up my torsion bars anymore the adjusters were full of crap making it impossible to wind up 5 mins with the water blaster and i have the front of the truck more or less even now.
i am however looking at putting 31s under the truck when these ones wear out some more but i was just wondering if they'd fit ok.
wildplumdx
Re: l200 on 33s
i got 31 buckshots on mine, mint as didn't need raising i dont think but i chucked 50mm body lift in it anyway maybe it was rubbing ? i dont remember but the buckshots ive put 56,000 km on them so far and i'm down to 5mm tread not very good in the mud now but its more a work truck then mud truck but the buckshots are worth every penny guys say you get about 75000 out of em i believe i will, just gotta rotate them every 10,000 and i pump them up to 40psi seems to be working trying to save the cutting edge of the tyre for mud when she see's it on building sites lol
- tirantious
- Bush Crasher
Re: l200 on 33s
just wondering what the best option would be a body lift or suspension lift can get a body lift of trade me for around $250 or i got quoted $1500 excluding gst or shipping for suspension. anyone know of anything cheaper?
Re: l200 on 33s
Don't forget you need cert for bodylift, about $400. Could get away with winding up torsion bars, make or buy longer shackles for rear leafs and fit longer shocks.
wildplumdx
Re: l200 on 33s
i have a body lift no cert and pass wofs all the time ? gone to numerous different garages no ones said a thing ? when i did it im sure people said you dont need one
wildplumdx
Re: l200 on 33s
btw suspension lift where on earth is that from i couldnt find jack for l200s?
Re: l200 on 33s
You may get away with it but legally you need a cert for any bodylift.
Re: l200 on 33s
zukmeista wrote:You may get away with it but legally you need a cert for any bodylift.
Big point here.... and its not the cops you really should be worried about, its insurance your body lift gives the insurance companys an easy out if they don't want to pay for you or anybody else involved
Just because you got a warrent doesn't make you legal lol
as far as legal goes the suspension lift is the "grey'er" of the two because of the longer travel springs in 4wd's there is a greater range of ride height due to sag so you will get away with a bit more "its just new springs..."
body lift blocks on the other hand are an obvious mod that isn't factory
- tirantious
- Bush Crasher
Re: l200 on 33s
wildplumdx wrote:btw suspension lift where on earth is that from i couldnt find jack for l200s?
ironman 4x4 they quoted me 1500 excluding gst for it plus i could pick it up from there rep on the way to visit the folks but i was just curious if theres anything cheaper out there/better options.
Re: l200 on 33s
I would seriously think twice about spending $1500 on a spring lift for this?
It is just a daily driven hack yea? There are much cheaper ways to lift a leaf and torsion sprung truck..
If I had $1500 I wanted to blow on a truck it would be new muds 31s $1000 and a locker $500
Re: l200 on 33s
And don't get caught up on 33s, a locked truck on 31s will go further than unlocked on 33s
- tirantious
- Bush Crasher
Re: l200 on 33s
yep i have given up on the 33s idea but i cant fit 31s under the front end of truck even with the torsions cranked up so the lifts to help squeeze them under and after that a locker and winch setup will be on the cards.J_Dub wrote:And don't get caught up on 33s, a locked truck on 31s will go further than unlocked on 33s
Re: l200 on 33s
a grinder costs 100 buks hammer 20 buks im sure you can make them fit. if you listen to the positive coments you will end up with cool truck if you listen to the negative nothing will get done! my truck had 29" wheels it now has 35" wheels. will post picks when complete as I have to many people saying cant do that!
do it do it
do it do it
Re: l200 on 33s
My L200 has 31's and I have the bumps tops cut back and torsion bars up to the max and I still had to cut the bumper and the rear of the guards at the bottom to get clearance.
I am using rims with extra offset to fill the bubble arches it has though.
I don't think 33's would work without a body lift or major surgery.
