Wanted: 25 Litre container
icekayak
Post by icekayak »
Looking for a couple of 25L containers to make into a water/waste water setup for the back of the van (must be at least 24L to meet the self containment certification).
Anyone got some lying around in Auckland cheap?
Even if not suitable for drinking water, will still need one for the waste water...
slighter lower and wider would be ideal, but otherwise just the standard cube type ones.
CLUMZ1
Re: Wanted: 25 Litre container
Post by CLUMZ1 »
drop in to your nearest car cleaning place - usually cleaner comes in those 25L plastic square drums
DieselBoy
Post by DieselBoy »
http://www.plastic.co.nz/
This is what Im going to use in the future to get the certification:
http://www.plastic.co.nz/plastic-products/6120.html
Think they are about $35.
icekayak
Post by icekayak »
Sweet will try that...
Bunnings have them and their blue (so wont have to muck around blocking the light) but they want $38ea for them. Just seems fairly steep when you can buy one full of chemicals for not that much more!
Have found this place http://www.amoraromatherapy.co.nz/index ... ts_id=1040
so might check out how clean they look...
Smurf
Post by Smurf »
Got a local binn inn? Our local one sells the used bulk vinegar 20/25 litre containers for $5 each
sako13
Post by sako13 »
Or if you live near wine country go into any winery and ask for any Gecol (Gelatine) or enzyme containers. They are usually white, certified food grade and UV stable etc. I go through probably 40-50 of them a season and usually just give them away or boost them in the bin. If you in the SI I can fire some your way if you want
icekayak
Post by icekayak »
Sounds like a plan :) I knew there must be some around!
