Safari manual gbox notchy
brakes-shocks-lockers-etc
Gren
Post by Gren »
What are your cures for a "just enough to be annoying" notch shifting gbox?
Does anyone run an additive to smooth out the shifting?
Cheers all
Trundle
Re: Safari manual gbox notchy
Post by Trundle »
If your clutch is set up correctly and pressure plate in good condition ,
Moreys heavy duty oil stabilizer or lucas also do one,
The alternative is redline blue oil but keep in mind these gearboxes are a big truck box and are quite industrial to change gears with
Swamped
Post by Swamped »
aussies rate that nulon g70 additive. castrol vmx seems to be a good oil too.
DaveM
Post by DaveM »
Replacing the nylon bushings on the bottom of the gear stick can make a difference too
Gren
Post by Gren »
All good comments guys thanks.
I've just now changed the oil to the castrol vmx 80 and holy crap what a difference!
Cheers guys, I'll go find some more annoying pieces to ask questions about now.......
