interesting read on oil for your engines
jonossiksilvia
Post by jonossiksilvia »
Re: interesting read on oil for your engines
Cool, thanks for the info
catalystracing
Post by catalystracing »
Good Stuff, cheers
Bubba
Post by Bubba »
I only got to chapter one... :oops: its a good read, I just need to brain my rest...
Benjamin Franklin
kiwipete
Post by kiwipete »
Someone care to put it into basic laymans terms ;-)
It's a lot of reading. :oops:
Ph 0212078472
tweake
Post by tweake »
main points.
oil protection is from oil flow not pressure.
so thicker than normal oil has poorer protection.
you want a thin as possible oil that you can get away with. so closer to minimum pressure is best. but you have to take in account that when very hot, oil thins out, you loose oil pressure and could go below minimum.
so you don't want to go to thin or you improve the oil cooling.
wide spec oils are best for engines that do short trips. ie oil is reasonable thin when cold to provide good cold protection. but the downside is the viscosity improver's they use degrades with use. so better protection but won't last as long.
wider the temp spec the more improver's and also more synthetic oil is used. that increases the cost.
then theres the oil specs themselves. the W spec is measured at 0c while the hot spec is measured at 100c. that gives you a rough idea of how thick it is at the temp your engine runs at.
hope that helps a bit.
kiwipete
Post by kiwipete »
Cool, thanks. :)
Ph 0212078472
Return to “Tool Shed”
