Swivel box shimming, 94 safari
For all Nissan related topics
Gren
Post by Gren »
I've put it off long enough but time is come to replace the leaking seals on the swivel boxes.
I'll be doing the bearings and seals in there at the same time, I have but one question.....
When I put the new king pin bearings in will that affect the amount of shims I need for correct adjustment?
Currently the front boxes are running none top/bottom on the left and one on the top right sides.
taz01
Tazzles
Re: Swivel box shimming, 94 safari
Post by taz01 »
should have 1 shim at least on all being new kingpins Id want them in for correct fitting as they get close to worn out then is the time to remove em
WARNING:
Gren
Post by Gren »
Hmm ok anyone got a set of shims for me?
just re fit the shims you have where they came from then check the pull load as in the shop manual,
I just did that in the three time I've changed king pin bearings, no problems so far
Return to “Nissan”
