change of rim size from 15" to 16" on my Surf ?
GNTONC
Post by GNTONC »
hello, just curious, is it legal to change the rim size on my Surf from 15" to 16" or do I need to certify that ? I just came around some cheap wheels but they are 16" (normal size on my 1995 Surf is 15"). they would fit without modifications.
cheers,
steve
zukmeista
Re: change of rim size from 15" to 16" on my Surf ?
Post by zukmeista »
Yes changing the rim size is fine but from memory you are only allowed a max of 5% increase in tyre circumference before you require a cert, but as long as your tyres aren't sticking miles out you can usually get away with it.
GNTONC
Post by GNTONC »
thanks
steve
Return to “Toyota”
