I'm following a couple of rumours, Are all Mazda gearbox's and bell housings compatible? as in can I put a bell housing form a rwd mazda onto a 4wd gearbox to mate the engine to it?
And what gearbox's are easy to work with? As in when did electronics take over??
I'm looking at mating a 20B 3 rotor to a Mazda 4wd ute Auto and using it in a multi purpose tube frame truck.
Doing a bit of work on gearbox/transfer is fine for me, just trying to make it easy if I can and also makes swapping spares in a lot better!!
(Yes, I've already been told I'm nuts!)
