Wanted V6 vitara transferbox and 15x8 rims
For all Suzuki related topics
escudoboy99
Post by escudoboy99 »
Hi there all. I am after a couple of things for my zuki.
Has anyone got a V6 vitara transfer box lying around or knows where one could be, before I ring up wreckers etc.
Also I'm after a set of 4 15x8 steel rims, In good condition. Thought Ill try before I end up getting new ones from mud bits etc.
Cheers all!!
dan88
Re: Wanted V6 vitara transferbox and 15x8 rims
Post by dan88 »
has your transfer case given up the ghost?, how did the gearbox re-build go?
churchill
Post by churchill »
You might be able to use a 1600 transfer case?
escudoboy99
Have decided to stick with the v6 T case now but am not replacing some components as they are too costly. Gearbox is all back together with new bearings and 1st & 2nd syncro rings. Will get the lot back together complete and back in the zuki soon as the 1600 gearbox with my welded on input shaft extension has given up with alot of abuse. So out with that and in with the original box!
Return to “Suzuki”
