So my idea was to go raid pick a part and find a small slip on style disc and matching caliper, get the disc redrilled to match the driveshaft flange and make a caliper bracket off the original drum backing bolt holes. Plumb this up to a trailer master perhaps with a modified handle to get better leverage, cut the base leg off that the coupling would push on of course.
Should work well in my mind, is a trailer truck so doesn't need the handbrake to hold for huge amounts of time.
Thoughts, ideas, criticisms, additions anyone?
Any input appreciated before I go ahead and waste my time making something that isn't going to be any use
