Anyone got one? Need a wiring diagram asap for an A343 Auto Gearbox, if not a diagram, just an idea of what each wire does...
heeeeelp
bill
Wiring Diagram for A343 Auto
Who knew Prados could fly?
Had a mate just do this conversion, had a nightmare with the auto computer and wireing and ended up with an aftermarket computer and a hefty overdraught.
Not much help i know, so good luck. if you get real stuck i could try to find out who the sparky was that did his, he may be able to lend some advise?
Bill, have a talk to Dave at Falsgrave Auto Spares. With his Lexus conversion he has wired his auto up with switch's and manually switch's gears, not sure of all the in's and out's but seems to work alright.
This might get you in the MUD till you come up with the correct solution.
GET SHIFTING,
FITZY.
GET SHIFTING,
FITZY.
