sas'n up my surf
truckingood
sas'n up my surf
Post by truckingood »
so as per title im in there. found out the guy up the road is on the move and after 25years in the same place he had a lot of shit to get rid of. one of them was a 87 lux on 32'' re-treads, mint runner with abit of rust in cab. after parting with a grand its up my drive. have looked through just about all treads and cant find my answer. my question is, when I do my change up, do I have to swap out my t-case aswell? as effectively the "push button" 4wd wont work with the removal of the add system???
any help is welcomed with much love
cheers luke
Smurf
Re: sas'n up my surf
Post by Smurf »
1987 Surf should be a LN/YN61 2 door with fibreglass canopy. It doesn't have the ADD system, It will have a W56 gearbox and a manually operated transfer that moves in a U shaped pattern from 2 hi to 4 hi then 4 low. So it will be fine as is for a SAS.
truckingood
suppose I should have sed my surf is a 94 kzn130 ifs with add set up (push button 4wd). donor vehicle is a 87 single cab hilux solid front with 4.3 lsd's. as my truck will be losing the button, will I need to swap t-cases as effectively there will be no way of tranfering drive to the front wheels :?
Smurf
Post by Smurf »
Can still use your transfer.
The push button engages the front drive in the transfer as well as engaging the ADD in the front diff. From memory you just need to do something with the wiring to the front diff.
Push button to engage 4wd works the same still.
truckingood
minta. let the skined knuckles begin :lol:
Dannz71
Post by Dannz71 »
good stuff mate, i just finished my surf sas!
stoked as, post ya progress and take heaps of pics
Cheers Dan
truckingood
yeah will do need to become a supporter first. then learn how to use the camera :lol: if any one is after a set of cleated mud chains, I have some of those for sale shortly too.
bob_or_jim
Post by bob_or_jim »
Hi mate, what you’re doing is not too hard at all. I’m picking your keeping the leaf setup from the Hilux? As far as the Tcase goes keep the factory one and leave the wiring as is. All you will need to do is remove the vacuum solenoids for the front actuators and you will be fine. Means you can have push button 4x4 for those quick stints up the tar sealed road and not have to stop to engage it. Plus keeps everything factory (wiring, cross members etc.)
Good Luck!
truckingood
cheers mate. na im going to ditch the leafs and go with a coil set up, keeps the same as the back. have a mate who used to run a suspension shop and is a certd welder and I only have to ask if he wants a beer and hes there :lol: any one got any pros or cons, leafs v coils?
The WEHI
Post by The WEHI »
Cheap and easy flex with leaves they work well and are simple :D
If we lifted from the rear wheel would have got full articulation out of the front,so bear in mind there's still some to go droop wise in the front.
trucks on 35's,1.45m to the center of the hub front bumpers at shoulder height,
The_wehi@hotmail.com
(027 788 1046)
Pzj77 Turbo/auto,33's .
truckingood
think I just changed my mined ^^ is this coiled rear?
tomsoffroad
Flopsie
Post by tomsoffroad »
truckingood wrote:think I just changed my mined ^^ is this coiled rear?
Yip all 130 Surfs are coil rear
The WEHI
Post by The WEHI »
Yup like tom said. the truck has 50mm body lift (gross) 50mm rear spring lift some old hilux rear leaves 50mm extended shackles? 50mm drop front cross member, and the rear suspension now lets it down,
(027 788 1046)
The WEHI
Post by The WEHI »
Maxed out the jack easily and the rear is slightly lower when sitting flat.
(027 788 1046)
Dannz71
Post by Dannz71 »
Yea mate leaves can provide heapsa flex if set up right. Just Dont let your shox restrict ya
truckingood
rito, leaves it is :D mite be on the move soon so will start a build after that.
Return to “Toyota”
