So basically cut the front eyes off main arms and used a couple of big rod ends for the new 3rd link and extended it all by 40mm to correct the diff roll caused from raised springs, I call this a 3 link as the original mounting seems to cause a lot of bind tending to lift the front wheel alot.
Cut original spring bases off and moved them forward as well,made a 40mm spigot bush for drive shaft and made some extenders for main arms where they bolt through the chassis
