Time for an oil change. Have looked on Google and found a few options. Is 9.5 liters what a 1HD-T takes? What engine oil do you guys recommend?
Cheers.
Best engine oil for 1HD-T
Re: Best engine oil for 1HD-T
10ltr with filter and Use Mobil delvac mx or sinopec have used castrol GTX diesel oil and a few others, running a HPR full zink 10ltr at the mo for a trial and Also throw a litre of moreys oil stabiliser in for good measure.
Cheers wopass, where would I buy either of those?
Are any of these any good?
http://www.supercheapauto.co.nz/online- ... 0105#Cross
http://www.supercheapauto.co.nz/online- ... 6857#Cross
i have tried the magnatec diesel and found it sooted and went shit very quick compared to the mobil delvac mx, havent tried the mobil super as its more of a small vehicle range as opposed to comercial/heavy from my understanding.
Where do you buy Mobil delvac mx? What type of oil filter would you recommend?
Most Repco have delvac mx and ryco filter Z334 and a litre of moreys heavy duty oil stabiliser. Chuck about 5ltr oil in then dump the moreys goo in then add another 4ltr of oil then run to fill filter and get pressure then shut down and check level and top up if needed.
So this is the one: http://www.hyperdrive.co.nz/product/oil ... 654/detail
Repco and supercrap only do 20 liters, nothing smaller for Delvac mx
luxsurf wrote:Repco and supercrap only do 20 liters, nothing smaller for Delvac mx
sweet you get a free oil change next time
luxsurf wrote:So this is the one: http://www.hyperdrive.co.nz/product/oil ... 654/detail
That's the stuff. I'm sure I got 2x5ltr packs last time... Maybe I got a 20... Can't remember. Or get it off waitomo Brennan in Hamilton or get synopec which is just as good (apparently)and cheaper.
the other good oil is gulf western j-power. http://www.gulfwestern.com.au/Diesel-Oil-JPower.html
getting hard to find jap specific oils now. mobil dropped there one.
not sure if its due to the common rails being closer design to the euro and usa ones.
I Picked up 2x5L from Repco last time it was on sale in their catalogue a month or so back.
