td05 wastegate springs
y60 safari driver
Post by y60 safari driver »
hi wondering if anyone can tell me where i can get some springs/ actuator to set desired boost pressure for a td05-16g off a wrx. had a search on trade me but with no luck
Twodiffs
Re: td05 wastegate springs
Post by Twodiffs »
Do you know which spring is in it already?...there's 2 types, parallel and a tapered spring. Try turbo shops or i can put up a Kinugawa link tonight which has everything.
crazyclark31
Post by crazyclark31 »
eBay my Man ,eBay. :mrgreen:
Heaps of them on there.
y60 safari driver
cheers, i'm new to turbos this one has a vacuum actuator controlling the wastegate, do you have to replace the whole thing or can you get at the spring inside the actuator? sorry if this has been covered before
crazyclark31
If you want to do it "properly" then just get whole new actuator.
Can I ask what type of td05 your running? And boost levels you want?
As the models running what's called a 'flat back' collar begin to ,not be very happy ,when running over 15psi all the time.
I know the td05h from the v5(?) wrx have the super back collar and the ones I've run/am running are good for heaps more pressure. Run 20psi with no issues. Can go more but at pump and autos limit.
This is just from my experience and I have been wrong before :lol:
