WTB: Nissan GQ 24v air con compressor
Looking for an air con compressor from a TD42 24 volt.
Re: WTB: Nissan GQ 24v air con compressor
might help if you put your location up
datsunsafari wrote:might help if you put your location up
Dirty old Gore, riviera of the south.
coxsy wrote:http://www.trademe.co.nz/motors/car-parts-accessories/nissan/engines/auction-726182049.htm
Yeah I've seen that one before, trying to find something undamaged.
Wouldn't really know where to find another pulley.
I brought a spare air con pump, when I got another steerbox. but GQ run the nasty aircon gas , and coms need new seals to run the less efficient, gas they have now
coxsy wrote:I brought a spare air con pump, when I got another steerbox. but GQ run the nasty aircon gas , and coms need new seals to run the less efficient, gas they have now
It won't be for air con, I'm going for an endless air setup. I thought if I use the original compressor it will be easier to sort out. I will probably put a grease nipple on it as I believe they don't run any type of greasing system from the factory.
marmel wrote:coxsy wrote:I brought a spare air con pump, when I got another steerbox. but GQ run the nasty aircon gas , and coms need new seals to run the less efficient, gas they have now
Put an inline oiler on the inlet side - about $5 from Supercheap. Or plumb the air inlet to the rocker cover breather to get nice oily air
muddy wrote:marmel wrote:coxsy wrote:I brought a spare air con pump, when I got another steerbox. but GQ run the nasty aircon gas , and coms need new seals to run the less efficient, gas they have now
I assume I will need something on the outlet to remove the oil then, catch can etc.
what! I. love my aircon, sod all air flow in these aircon cars without it
coxsy wrote:what! I. love my aircon, sod all air flow in these aircon cars without it
Doesn't get hot enough in the deep south to warrant aircon. Certainly not the humidity you guys up north get anyway.
Grease nipple works fine, mine done this way, been running for years without problems. Check out the endless air website, that's how they do it.
I'm running an air tank which lets the oil & water settle out. You could also put an oil separator on the outlet
