Hey guys I got a Ln65 Hilux. 3 inch shocks with 2 inch body lift on leafs and when I'm in full lock right I think it's the control arm? Unsure exactly but it pushes against the drivers side shock only just noticed this and it's too late since the shock now has been dented.
What is the solution to fix this and will a dented shock fail me on cert?
Front shock damage
Re: Front shock damage
do you have a pick of the issue, we stock a number of front end parts for your truck ,
Trundle wrote:do you have a pick of the issue, we stock a number of front end parts for your truck ,
Don't quite understand, sorry.
He means a pic, as in photo....
DaveM wrote:He means a pic, as in photo....
Oh yup makes sense. I'll get a picture tomorrow or Sunday depending. Thanks.
- mudlva
Wolf wrote: and will a dented shock fail me on cert?
answer yes
http://i1003.photobucket.com/albums/af1 ... NY0030.jpg
http://i1003.photobucket.com/albums/af1 ... NY0029.jpg
Here's the pictures.
Thats the draglink for steering, would adjusting steering stops help
Wolf wrote:Hey guys I got a Ln65 Hilux. 3 inch shocks with 2 inch body lift on leafs and when I'm in full lock right I think it's the control arm? Unsure exactly but it pushes against the drivers side shock only just noticed this and it's too late since the shock now has been dented.
I think its caused by the larger bore shocks and the suspension lift, it should get slightly worse when you flex with compression on the drivers side?
Possible solutions are:
-Smaller bore shocks my old man emu ones are fine but im only around a 2 inch lift, what's the o.d of the bit on the shock that rubs? i could measure against mine if you like
-Ditch the standard steering and do the high steer conversion but that's mighty expensive but the ultimate fix to the average stock steering
-Or as mentioned above limit the steering some more but they have a crappy enough turning circle already.
trucked wrote:Wolf wrote:Hey guys I got a Ln65 Hilux. 3 inch shocks with 2 inch body lift on leafs and when I'm in full lock right I think it's the control arm? Unsure exactly but it pushes against the drivers side shock only just noticed this and it's too late since the shock now has been dented.
Okay thanks.
I don't think I'll get smaller bore shocks as I'd have to replace all 4 to match that could be expensive? (I think).
High steer conversion would be great how expensive we talking there?
I don't mind doing 100 point turns lol. As long as the problem get's fixed. Otherwise I'll be doing no turning.
Thanks, guys.
