Ok, all you Nissan Gurus out there in 4wd land!
We want to mount a tacho to Richies Mongrel. (mongrel being a thing of many, varied and mixed parentage)
Is there a stock item?
Is it mechanical or electric, read electronic.
Where do the pickups go if electronic.
Or are we faced with an after market gizmo?
Thanks........ Bob.E
LD 28 Tacho
- Moriarty
Re: tacho
coxsy wrote:found the sensor it's fitted to the desiel pump on a 2.8
THANKS!!
Will get a tach from the wreckers and we shall see if it all works. Will post results of this experiment here.
