d21 diff swap c200 to hg233b
lockednloaded
- Stropper
Hey guys I have a 1990 datsun d21 4x4 4banger na20 , I'm looking at options for my rear diff I want to put a locker in as it has a c200 open rear diff but the only available is an arb locker which im not that keen on , so I'm trying to figure out if a can get a complete drum to drum hg233b open diff out of a later model v6 d21 and will it bolt in without any major modification? Or would a safari hg233 fit? The c200 runs a 4.8:1ratio and from what I have seen so does the hg233. Has anyone done this conversion before? The hg233 means I can install a lock right locker and they seem pretty bulletproof cheers Jed
- Crash bandicoot
Re: d21 diff swap c200 to hg233b
lockednloaded wrote:Hey guys I have a 1990 datsun d21 4x4 4banger na20 , I'm looking at options for my rear diff I want to put a locker in as it has a c200 open rear diff but the only available is an arb locker which im not that keen on , so I'm trying to figure out if a can get a complete drum to drum hg233b open diff out of a later model v6 d21 and will it bolt in without any major modification? Or would a safari hg233 fit? The c200 runs a 4.8:1ratio and from what I have seen so does the hg233. Has anyone done this conversion before? The hg233 means I can install a lock right locker and they seem pretty bulletproof cheers Jed
some of the Navara's came out with a LSD c200 or a WD21 pathfinder/terrano, or change out the complete axle for a HG233b from a terrano or pre facelift mistral with the clutch pack LSD. or get your hands on the LSD or locker from a silvia legacy skyline cefiro laurel 180sx 300zx.
from memory you'll be needing the 29 spline diff head if you only want to swap the center out. Don't get the R50 axle i think they are 31 spline with bigger brakes.
car50 had the 33spline stern (drum braked version of the Y60 Safari unit) Stupidly big unit for the application.
Sh^tloads of info here on Nissan diffs and interchangeability, just a search away and comb through the info.
Leafs vs coils... a linked rear end won't exactly bolt in..H233 4.88 gears not exactly common either
4wdsystems in Australia make Lokka/Lokrite/Aussie Locker for the 4-pin C200. That or an LSD would be the easiest as crash says
Some late model d21 navaras have the h233 rear diff fitted as oe (leaf sprung)
The factory turbo double cab purple ones all seem to have it fitted
Maybe look into one of those (some have factory diff lock too
slide wrote:Some late model d21 navaras have the h233 rear diff fitted (some have factory diff lock too)
Now that's new and interesting! I very much want one of those please and thankyou
a possibility is the series 1 D22 h233b rear diff. the 4wd z24 engined one comes with 4.8 ratio.
lockednloaded
- Stropper
Thanks yeah I have been ringing around wreckers but none have come up with any tails on a complete axle , I just discovered that lokka makes that c200 locker so that would probably be the way to go,will be a far more capable truck with that
hamboy wrote: I very much want one of those please and thankyou![]()
Only problem is they are drum brake and leaf sprung, so not really that easy to fit into wd21
Would be interesting to know if locker has 31 or 33spline spider gears
There is a complete terrano disc to disc 4.88 ratio lsd on Canterbury 4wd and beyond facebook page atm for 150
lockednloaded wrote: I just discovered that lokka makes that c200 locker
You've gotta be shitting us.
slide wrote:hamboy wrote: I very much want one of those please and thankyou![]()
Only problem is they are drum brake and leaf sprung, so not really that easy to fit into wd21![]()
Would have thought the actuator would be in the diff housing rather than the main beam?
- Crash bandicoot
lockednloaded wrote:Thanks yeah I have been ringing around wreckers but none have come up with any tails on a complete axle , I just discovered that lokka makes that c200 locker so that would probably be the way to go,will be a far more capable truck with that
Ring Jason at Niscars ltd down in the Gracefield, wellington if he ain't got one he will find one 0800 232233
