About to fit my new Auto transmission Cooler, and want to know ,do I fit it in the return line to the auto, or in the out line to the Radiator?
Its going on a 3Lt Prado KZ
Auto Coolers
Auto Coolers
;-p
i went from (in my Phaatsun) trans out to radiator-radiator to cooler-then cooler back to trans. idea is that the radiator will be hot with water so having it go thru the cooler after its been thru the radiator is gonna keep it cooler
did that make sence ?
Hi Kev, my son has had an extra trans cooler fitted to his 97 Surf by an Auto shop in Nelson. They fitted it in the outlet line from the trans, through the extra cooler then into the bottom of the radiator cooler, so it is plumbed into the line from trans out to radiator, hope this makes sence.
IT'S LATE ---- OR IS IT EARLY ???,
FITZY.
FITZY.
Trans Cooler
The general theory is that you install them in the line from the trans to the radiator cooler. This ensures that the fluid goes back to the trans at a reasonably constant temperature.
The cooler before the radiator removes heat before the fluid goes into the radiator making life easier for the radiator and engine as well.
If you put the cooler in the line from the radiator to the trans then on really cold days the trans gets cold fluid and that is bad.
- mud_slinger
