7th-8th June
7th-8th June
started to see if the 24v ARB pump will fit were the little 12v pump was, it will with some work,
down side ,found broke battery terminal, Repco to the rescue , have a spare terminal now too :D
replaced broken left side mirror dam trees at woodhill
catalystracing
Re: 7th-8th June
Post by catalystracing »
Replaced both diff oils, and serviced the front wheel bearings, adjusted hand brake...ready for the WOF and the next 5000ks :D
Pedro
Re: 7th-8th June
Post by Pedro »
pulled 80 series housing out of front of disco, managed to bend it a while ago, cut all brackets off, rewelded to replacement housing and reassembled the bloody thing, drove around the block, major improvement to steering....
Pedro
drive it ...
Re: 7th-8th June
Post by drive it ... »
Pulled rear diff head out and replaced couple of broken studs. Put much more goo round the seal this time so hopefully it wont leak and then I wont break studs over-tightening it to stop the leak. :oops:
Sheepy
Re: 7th-8th June
Post by Sheepy »
Did a Body lift on my hilux. Much better. Nothing rubs now.
holmz3
Re: 7th-8th June
Post by holmz3 »
Pulled front drums off my fj40 and stripped down knuckles just gotta clean everything up , what a messy job!! Then wait for all my new bits to arrive to put it back together with the disk brakes I'm getting off Jason (classic cruiser spares) looking forward to having breaks and piecing all the bits on my garage floor back together, need new steel brake line now tho after sharing the end off it I'm bloody good at taking things to bits n breaking them it's the putting back together I struggle with but wel worry bout that next weekend :roll:
Shrapa
Re: 7th-8th June
Post by Shrapa »
Achieved didly squat this weekend while back is injured. Did manage to notice rust under rain gutters in the 60 series has come back with avengance! :|
Mhmm too many options to consider now:
A: Panel beater to cut out cancer.
B: Find a new roof.
C: Cut old roof off and convert to soft top..
"Keep the shinny side up"
Crash bandicoot
Re: 7th-8th June
Post by Crash bandicoot »
Shrapa wrote:Achieved didly squat this weekend while back is injured. Did manage to notice rust under rain gutters in the 60 series has come back with avengance! :|
B: Find a new roof.
option C :D
snatch22
Re: 7th-8th June
Post by snatch22 »
helped the young fella put the waterpump in scruba(terrano) and put the exhaust manifold back on the safari
Slideways
Re: 7th-8th June
Post by Slideways »
Made some heavy duty sill protector/side steps for my Safari.
Ant
Re: 7th-8th June
Post by Ant »
Slideways wrote:Made some heavy duty sill protector/side steps for my Safari.
Looks awesome, any chance of pics of your mounting points? Do you have a body lift? hoping to start mine in the next few months.......although I have said that before. I've spent the last few months cutting off my roof and putting a new(er) one on the safari, just finishing up some sanding and painting then onto the bar work.
92 LWB Safari TD42
Slideways
Re: 7th-8th June
Post by Slideways »
Ant wrote:Looks awesome, any chance of pics of your mounting points? Do you have a body lift? hoping to start mine in the next few months.......although I have said that before. I've spent the last few months cutting off my roof and putting a new(er) one on the safari, just finishing up some sanding and painting then onto the bar work.
Cheers, yep I'll take some photo's of the mounting points once I've finished welding them. That photo is a test fit with mounts tacked on.
No body lift, I did massage the sill lip inwards (no cutting) to give a bit more room but wasn't strictly necessary. It would be easier with a body lift but I don't plan on it.
Re: 7th-8th June
i leave pinch weld alone,leave a gap of ten mm between box section an pinch weld for flex :D
Filthy4x4
Re: 7th-8th June
Post by Filthy4x4 »
Went up to Possum Palace with Andy3542, Lexlux and a few others which I dont think are on here... Had an awesome weekend setting tracks. Big thanks to those who came up and helped us.
Cant wait for the comp :twisted:
027 MUD GEAR - (027 683 4327)
Check our facebook:
zukmeista
Re: 7th-8th June
Post by zukmeista »
Another awesome video, keep up the good work! :D Looks like you've found a great place for a winch comp. 8)
hamboy
Re: 7th-8th June
Post by hamboy »
Had a club trip at Mt Riley, had heaps of fun trying the winch challenge tracks. Also got strapped into this thing
:mrgreen: :mrgreen: :mrgreen:
Craydiver
Re: 7th-8th June
Post by Craydiver »
great video.
Is the LSd working right on the v8 lux?, on the uphill winch piece it didn't seem to be engaging.
however it appeared it didn't slow him too much!
Ashohman
Re: 7th-8th June
Post by Ashohman »
what if its got lockers and didn't have on then open diff.
LOLYF
Re: 7th-8th June
Post by LOLYF »
Craydiver wrote:great video.
He doesn't have an LSD, The air locker is broken so running a temporary open diff.
But your right it doesn't slow him down much!
Tonkatoy.
Re: 7th-8th June
Post by Tonkatoy. »
hamboy wrote:Had a club trip at Mt Riley, had heaps of fun trying the winch challenge tracks. Also got strapped into this thing
Those RZR's are great fun, we have a class for them at Off road racing events. Buckets of fun......
If there's no Blood it ain't Hurt
1999 Jeep Wrangler Sport
OIIIIO
hamboy
Re: 7th-8th June
Post by hamboy »
This one is last years class winner
