Hi all,
I'm after a new truck. Looking for around a 1994 Surf 1KZ that has been well looked after and maintained. Wanting one that had. Few mods already.
Based in chch but happy to travel around nz!
Please txt/call: 027 seven one 0 seven 062
WANTED: Surf 3.0L Turbo Diesel (modded)
1997 Toyota Surf KZN185 Intercooled, Silver/Grey, 2" Suspension Lift, 285/75/r16 Hercules Terra Trac D/T, 16x8 ROH Black Track Steelies, Roof Cage, 42" LED Light Bar, Limb Risers, Snorkel, Auber Gauges, Thicker Core Radiator, MCC Winch Bar
- jonossiksilvia
Re: WANTED: Surf 3.0L Turbo Diesel (modded)
This is not trademe so you dont need to to disguise your number.
Good luck on the hunting though. One important thing is try to look out and see if the heads been done.
Bump, still looking for one!
Bump
Regretfully up for sale is my 1995 Hilux surf 3.0 Diesel 1kzte
It has been extremely reliable, starts first time, every time.
Has a few modifications, all done to a very high standard with quality parts.
No longer has the common heat issues
Very capable off road – built for soft Wellington sand, loves mud holes. Also has very good road manners.
· 193,000 Km
· WOF 8/8/14
· Reg 25/5/14 will put more on
· RUC 197,100
· Cambelt was done at 186916
· Both batteries were replaced on 20/10/2012, CCA was increased
· Has had a HUGE service about 6 months ago including; new Transmission and transfer case oil, new Diff oil, new front and rear brake pads including front callipers rebuild and new cylinders in the rear and new fluid, new engine oil and filter, new fuel filter, new air filter.
· At the same time I instated a Davis Craig 8 cylinder Transmission cooler.
· The rear brakes get adjusted frequently (Drums)
· About a month ago it got a brand new Silverdale 53mm 3 Core manual radiator, Engine oil and filter with semi synthetic oil, Viscous Hub rebuild (new fluid)
· Has a big front bar and powerfull spotlights
· 9,000Lbs Thomas Winch
· 50mm suspension lift with old man emu shocks all round
· 33x12.5r15 tyres on 15x8 steel rims including spare, good tread on all round
· Airflow Snorkel
· Aisin Manual hubs
· Rated 12,000Lbs recovery hooks front and rear
· Onboard air with adjustable pressure switch, pumps tyres up from 10psi – 38psi nice and quick, also have a tank that just needs to be installed.
· Diff Breathers front and rear
· Aftermarket Defi engine temp gauge
· Removable dropped towbar
· Intercooler and fittings ready to be installed.
· CB radio 80 channel
· Fire extinguisher
· Rear sway bar and running boards removed to help off road ability
Send me a txt as I'm not online often
0220901730
· 193,000 Km
· WOF 8/8/14
· RUC 197,100
· Airflow Snorkel
· Aisin Manual hubs
· Fire extinguisher
0220901730
Surf - 50mm lift, front bar, integrated winch etc
contactable on 0220901730
- Driver/Navigator
I'm thinking about selling my surf kz very standard tho on a/t's it still goes well off road even with a rally truck on a trailer. looking around 6k less than 200 thou k's.
jesse.woollett wrote:I'm thinking about selling my surf kz very standard tho on a/t's it still goes well off road even with a rally truck on a trailer. looking around 6k less than 200 thou k's.
Any photos mate?
- Driver/Navigator
will try and get some this avo.
