Can any one tell me if the rear brake shoes off a 413 with the hand brake on the rear diff is the same as the 413 with the hand brake on the transfer case I'm after new rear brake shoes for my 413 it has the hand brake set up on the rear diff
Cheers for any help
Sj413 rear brakes
Re: Sj413 rear brakes
Don't think so, there are a few different ones so make sure you get the exact ones for your vehicle. Also handbrake on rear wheels=Samurai not SJ413. Should be a plate on the firewall with chassis no. etc on it chassis no. should start with SJ50 or SJ70 this is what you need to get the right shoes.
They are different to the rear break shoes, they are the same as Suzuki carry ones iv got a spear pair of you get stuck
fyc 4wd wrote:They are different to the rear break shoes, they are the same as Suzuki carry ones iv got a spear pair of you get stuck
That's the brake shoes for the transfer mounted handbrake he wants the shoes for the drum brakes on the rear axle.
