Purchased some carbon sheet from C-Tech, this stuff is incredibly strong even .5mm left on a corner cut is nearly impossible to pull off!
Anyway, cut out the holes with grinder/dremel and used gorilla glue to put components in.
The carbon panel is held in with four screws on the corners so it makes it easier to get to wiring if required rather than have to pull the hole centre piece of the dash out.
What you see in the pic is a screen for reversing camera plus second camera to be mounted up front somewhere, haven't decided where yet. Two Auber gauges for EGT and boost, GME TX3100 UHF and switch panel for various things. I have a couple more switches for winch which will go in bottom right hand corner.
I also have extra carbon sheet if anyone wants some. PM me.
I will post a few more pics once installed.
[/URL]
