Anyone got some or know where i can get some. wreckers?
If no luck here ill order new from Japan.
Going to try fit them to my Pajero iO,
Glen
Wanted, 5.29 for gen 2 auto Pajero (jtop) (FOUND)
Pajero iO with 31", front and rear lockers and stuff...
http://WWW.PAJERIO.COM
Re: Wanted, 5.29 for gen 2 auto Pajero (jtop)
Try wreckers.... The 2.5 diesel LWB should have the 5.29 as well.
Thanks NJV6
got any links to wreckers in NZ? Im from Australia, no luck finding any 5.29 here.
www.outback4x4.co.nz I use these chaps quite often
- Team Tonka
Hi, I have 5.29 diffs sat in the shed from a 92 Diesel soft top. Front is the smaller diff which is why I changed to 4.865 as they don't do a locker for it. Rear one is factory air locker. What are you looking for, crown wheel and pinions or whole lot? Would want $1000 for complete rear axle and front diff. Rear axle includes locker electrics, compressor, brain, switch etc. I'm in Rangiora. Cheers Andy.
May the force be with you.
Thanks guys,
I only need the crown wheel and pinion, I already have some lockers i want to install them on.
I also just remembered the soft tops have a 9" rear diff, i think..? my rear is 8". I actually have a 5.285 9" rear sitting in the warehouse already.
So only the front would be useful to me, i Dont suppose you would be interested with parting with the front only?
I have tracked down a new 8" for the rear if I need, so half way there.
You won't get a locker for the 5.29 front as they never came out in 8 inch. You can however put the 8 inch rear 5.29 from gen 1 paj into 8 inch gen 1 low pinion front and get a front 5.29 air locker that way.
Getting those bits would be getting hard to find now I'd imagine
Any yes, all gen 2 pajero a had 9 or 9.5 inch rear diffs. The 9.5 never had 5.29's.
I already have a locker made for the 7.25, it fits! I have bolted a crown wheel on, I spent a long time tracking this down. Will share the info once its installed and i can prove 100% that it works.
I also have the large 9 or whatever size it is in 5.285 rear here if anyone wants one, $80 plus delivery. Thats what all Jtops are.
Part number is MB598486 ...
Team Tonka wrote:Hi, I have 5.29 diffs sat in the shed from a 92 Diesel soft top. Front is the smaller diff which is why I changed to 4.865 as they don't do a locker for it. Rear one is factory air locker. What are you looking for, crown wheel and pinions or whole lot? Would want $1000 for complete rear axle and front diff. Rear axle includes locker electrics, compressor, brain, switch etc. I'm in Rangiora. Cheers Andy.
Super keen on your front crown and pinion Andy!
I just noticed i missed a set of these that were advertised on my own website! http://pajerio.com/forum/sold-pajero-52 ... ment-16890 Im soooo annoyed, i created and own that website and i missed an add selling exactly what i have been wanting for a yr or so LOL.
Thanks Andy!
5.285 front diff is on the way.
